SOURCE: How to connect galaxy tab to TV
Welcome to Fixya. To connect the Galaxy Tab to a Tv you need to use the cable below. The cable is color coded so make sure you connect it to the right port on the tv. If it is already connected use the TV remote then look for an Input or Source button then select Video or TV/Video
Connect your Samsung Galaxy Tab to your TV with this Original Samsung AV Cable. The 30 pin to composite video cable will allow you to connect your Samsung Galaxy Tab to your television or projector easily.
This will enable you to watch videos and picture slideshows stored on your device. Connecting the Samsung Galaxy Tab to your TV or projector with this cable will also allow you to use the sound from your television or surround sound system to give a richer, fuller sound.
If you have questions please let me know. Thanks for using Fixya
SOURCE: How can i connect my 3G internet on Samsung Galaxy
This should help you out:
http://www.techtin.com/gadgets/how-to-turn-on-and-turn-off-3g-on-samsung-galaxy-tab/
SOURCE: I bought my Samsung Galaxy
It sounds to me like you have an issue with your Galaxy Tab's charging port.
Fortunately it is still under warranty if you've just recently purchased it.
Take it back to the store or contact Samsung for a warranty replacement. They may be able to help you recover items from the memory.
Hope this helped!
Thanks!
SOURCE: samsung galaxy tab . written manual I would like
http://www.samsung.com/us/support/downloads/SCH-I800BKAVZW if this helps please vote
SOURCE: samsung galaxy tab 2 10.1 wgxa model GT-P5113 is frozen
Hold the power button down for up to 15 seconds. This should hard reset it. Not to be confused with erasing data.
