I want a great tall commode that never needs plunging. I was told a cadet was a good choice. There are two cadets. I was told a 3 is as good as a 4 and easier to repair. Is this true?
I only install Kohler commodes and have never had a problem with clogging. All of Kohler commodes have a 3.5 inch flush valve, just pick the style you want.
who ever told youy 12 and 6 and 3 and 9,is crazy in the head,the first time you hit heavy grass on one side,that will change,the problem is your blades,your blades are probably 22 inch,they need to be 21.2 inches,and if they are,then your spindles have moved and you need to fix thathere is your parts list,and pics of the blades you need, Cub Cadet LT1042 13AX11CG010 Cub Cadet Lawn Tractor 2008 after Mower Deck...
American standard cadet III is a nice flushing toilet that is reasonably priced. The tank is smaller than the cimarron. Toto also makes good flushing toilets that would fit your needs, but you will pay more for it too.
Sounds to me like you might be having a problem with either your key switch, or more likely your starter. Although I have never had a starter go out on any riding mower Ive ever had, thats really what is sounds like. On the other hand, I have had many a key switch go bad and they act alot like your symptoms. So I would start at the simplest and work backwards.
Also, make sure blades are disengaged and also they are not bound up on the underside of the mower deck. also check the belt and its not in a bind. These thing could be dragging down your motor keeping it from starting. Let me know if I can help further. Have a Great Day! Good Luck!
Sorry to read about your problem, I hope this helps you out.
i would goto ace hardware or home depot, and buy plumbers goop, in a purple tube..
glue the little clips on,
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
the floor flange..where the toilet bolts go, should be on top of finished floor and screwed down .it should only be apox.3/8"higher then finished floor.you often have to cut a tapered hole so floor flange sits correctly
