Shark Navigator Bagless Upright Vacuum Logo
A
Anonymous Posted on Feb 22, 2015
How do I change the belt on my Shark Liftaway
Brush not spinning, can't get bottom housing off. Removed 6 screws.
Dan Schilz
Level 2:
Habit-Forming:
  • Expert 47 Answers
  • Posted on Feb 24, 2015
 Dan Schilz
Expert
Level 2:
Habit-Forming:
Answers
47
Questions
0
Helped
109287
Points
120
I have the Shark Professional Life-away. Maybe the same, or similar to yours. If its the same, there are 8 screws that hold everything together.
You probably found the two under the small rubber rollers located at the front bottom cover. There is one more hidden ***** under the "Hose Access" cover. Just pinch the two clips together (you may have to work these clips a bit to open the door) and you will see the last ***** inside.
The top cover should then lift off without a problem, just unplug the LED light cable (remembering its orientation) and you can get to the cover for the beater brush. Hope this helps!
Shark Vacuum power brush disassembly?
Screeching would normally be the belt slipping because the brush doesn't spin freely.
https://www.google.com/search?q=Shark+Vacuum+power+brush+disassembly
Other ideas on screeching.
https://www.google.com/search?q=Shark+Vacuum+power+head+screeching
tip
How To Replace The Belt on The Riccar 8850 Upright Vacuum
Greetings from GoVacuum,
I will attempt to walk you through the belt change on your Riccar 8955 upright vacuum cleaner. I have taken pictures for you for each step to ensure that it's done properly. What you'll need to have handy for this repair;
- Phillips Head Screw Driver
- Riccar 4000 / 8000 Series Belt
- Riccar 8000 Series Roller Brush With Clutch Assembly (only if the brushes have worn down, not necessary if brushes are still long)
Step 1: Make sure the vacuum cleaner is unplugged, and turn the vacuum cleaner upside down so the bottom plate is upwards. It's easiest to do on a work bench or counter top.
Step 2: Unscrew the two metal screws on the metal bottom plate with your Phillips head screw driver, and remove the bottom plate from the vacuum cleaner so the belt is completely exposed with the roller brush
Step 3: Remove the belt guard that sits to the left of the roller brush, and is a metal part that protects any dirt & debris from going over to the belt. Here's a picture of that part being removed;
Step 4: Remove the Rug / Floor actuator arm from the clutch on the right hand side of the roller brush. Simply pull the metal actuator arm to the left of the brush and out of the circle that it sits in. Here's a picture of that;
Step 5: Once you have removed the actuator arm for the clutch, as well as the belt guard, lift straight up on the roller brush and remove the roller brush from the vacuum cleaner:
Step 6: Once you have removed the roller brush, and the old belt from the vacuum cleaner, take one new belt and wrap it around the metal pin in the back of vacuum cleaners agitator housing. Here's a picture of where that pin is located with the belt wrapped around it;
Step 7: Once you have the belt wrapped around the metal pin (this is the shaft to the motor that actually spins the belt), but the other end of the belt through your new roller brush;
Step 8: There is a specific way that the roller brush has to be inserted. If the roller brush is not put in properly, this can cause all sorts of problems including the brush not spinning, and continuously having to replace belts. You can see on the end cap of the roller brush (the right side where the belt rides) that there is two little teeth that protrude out of the end cap as well as an indentation on the opposite side;
Step 9: With the roller brush inserted through the belt, position the two teeth facing downwards. You can see in the vacuum cleaner where the roller brush sits, a little groove down inside of the housing. These two teeth need to straddle that groove. Also make sure that the little ring, or circle that the clutch actuator arm sits into, is facing upwards completely. It should be directly on top of the two teeth. Stretch the belt using the roller brush as leverage down into the agitator housing of the vacuum cleaner, making sure that the two teeth are facing downwards straddling the little groove. After the brush is back into the vacuum cleaner, take the metal actuator arm from the rug / floor switch, and insert it back into the metal ring (or hole) on the roller brush;
Step 10: Replace the metal belt guard that rests to the left of the belt. You'll notice on the belt guard that there are two little 90 degree notches on both sides. These notches need to face towards the belt or to the right. Here's a picture of the belt guard being put back into place;
Step 11: After inserting the belt guard back into the vacuum, turn the vacuum cleaner over so the top of the agitator housing is facing you. Change the the rug / floor switch from bare floors to the carpet setting, and the turn the vacuum upside again so the brush and belt are exposed:
Step 12: With the vacuum set to the carpet setting, pull the belt forwards to ensure that the brush is spinning freely. If the belts do not spin freely, repeat steps 2-10.
Step 12: There is a flap that can be opened after the metal bottom plate has been removed, that will give you more access to the motor shaft. Make sure that this flap is closed;
Step 13: The last tricky part can be reinstalling the metal bottom plate. There is a little lip on the front of the vacuum cleaner that the edge of the bottom plate has to slide under for it to be installed properly. A lot of people just install the bottom plate over top of this lip, and this prevents the brushes from hitting the carpet as low as if the bottom plate is correctly installed. Here's a picture of the lip with the bottom plate in the backgroud;
Step 14: Slide the metal bottom plate into the lip on the vacuum cleaner, and fasten the screws back into the bottom plate to secure it. The lip is a little tricky, but after doing it just once, you'll have no problems in the future changing your belt.
Here's a picture of the bottom plate installed INCORRECTLY with the bottom plate over top of the lip;
Here's a picture of the CORRECT way to install the bottom plate:
I hope that this repair solution is helpful to you in installing the belt properly. If you found this helpful, please be sure to click the 4 Thumbs Up Icons in the top right hand corner of the solution. Feel free to request a clarification of the repair if you have any questions about this repair, or other repairs. I'm always happy to answer any questions.
Thank you very much,
Chris J.
on Mar 21, 2010 • Riccar 8850 Vacuum
tip
How To Replace The Belt On Riccar 8850 Upright Vacuums
Step 2: Unscrew the two metal screws on the metal bottom plate with your Phillips head screw driver, and remove the bottom plate from the vacuum cleaner so the belt is completely exposed with the roller brush.
Chris J.
2answers
My Shark pet hair power brush will not spin, and there are no answers here
You may have to change the batteries to make it work.. In the mean time just use it manually.....
19helpful
Change the belt
Hi There,
Here's how you can replace the belt on your Eureka SmartVac 4870. I have taken pictures of the repair to help you better with this.
Here's what you'll need in order to complete this repair:
- Eureka Style R Extended Life Replacement Belt, Part 61110
- Eureka SmartVac Model 4870 Roller Brush Assembly, Part 61520 (Only if the brush no longer spins, or the brushes are worn out)
- Phillips head screw driver
Step 1. Turn the vacuum upside down so that the brush roller is facing upwards. Unscrew the three screws that I've highlighted in red.
Step 2. Remove the bottom plate after unscrew the three red highlighted screws. Once you remove the bottom plate, you'll have full access to the roller brush and belt area. Remove the roller brush by pulling straight up on the roller brush itself. Discard old belt, and test roller brush to ensure that it spins freely by holding the very end of each side, also called the bearing caps with just your finger tips. Try spinning the brush with your thumbs. The brush should spin several times around with each spin. If you notice the brush doesn't spin at all, or if you feel some resistance when you spin the brush, this means that your bearings are either gone, or will be soon. It may be time to consider a new roller brush at this time.
Step 3. Remove the new Eureka Style R belt from the packaging, and wrap one end around the the metal pin, on the opposite side of the roller brush. This pin is actually the motor shaft that spins the belt, which spins the brush.
Step 4. Wrap the other end of the belt through the side of the roller brush that has the pulley, and use the roller brush to stretch the brush roll back into the agitator housing. Make sure the end caps fit in the housing correctly by making sure there are no gaps between the roller brush housing and the end caps of the roller brush.
Step 5. After reinstalling the roller brush back into the housing with the belt attached, pull the belt forwards towards the brush. The brush should spin when you do this. Make sure that the belt is not pinched underneath of the roller brush or this will cause the belt to break immediately when you turn the vacuum back on.
Step 6. Reinstall the bottom plate, making sure that the little notches on the front end of the bottom plate tucked underneath of the reverse notches on the bottom housing of the vacuum cleaner. Tighten all 3 screws back into the bottom plate. Make sure the vacuum is set to carpet mode, and turn the vacuum on.
If you have any questions about this repair, or if you notice that the roller brush stops when the brushes hit the carpeting, please just use the clarification request form here on the Fixya repair page. I will then be happy to walk you through a little more advanced repair of replacing the clutch in the Eureka SmartVac that controls the rug/floor switch. Most of the time though the belt will be all the vacuum needs.
I hope that this was helpful information to you. If this helped you, please be so kind and rate the repair as helpful by clicking on the thumbs up icons in the top corner of this repair.
Chris J.
GoVacuum
7helpful
How to replace the belt in the 8850 model
I hope that this repair solution is helpful to you in installing the belt properly. If you found this helpful, please be sure to click the 4 Thumbs Up Icons in the top right hand corner of the solution. Feel free to send me an email, or request a clarification of the repair if you have any questions about this repair, or other repairs. I'm always happy to answer any questions. Be sure to check out our website for any Riccar parts that you may need, including; Riccar Vacuum Bags, Filters, Belts, and Parts.
Chris Jones
GoVacuum.com
24helpful
How to replace belt on Riccar
Step 1: Make sure the vacuum cleaner is unpluged, and turn the vacuum cleaner upside down so the bottom plate is upwards. It's easiest to do on a work bench or counter top.
Step 2: Unsrew the two metal screws on the metal bottom plate with your Phillips head screw driver, and remove the bottom plate from the vacuum cleaner so the belt is completely exposed with the roller brush.
Step 5: Once you have removed the actuator arm for the clutch, as well as the belt guard, lift staight up on the roller brush and remove the roller brush from the vacuum cleaner:
Step 8: There is a specific way that the roller brush has to be inserted. If the roller brush is not put in properly, this can cause all sorts of problems including the brush not spinning, and continously having to replace belts. You can see on the end cap of the roller brush (the right side where the belt rides) that there is two little teeth that protrude out of the end cap as well as an indentation on the opposite side;
Step 9: With the roller brush inserted through the belt, posistion the two teeth facing downwards. You can see in the vacuum cleaner where the roller brush sits, a little groove down inside of the housing. These two teeth need to straddle that groove. Also make sure that the little ring, or circle that the clutch actuator arm sits into, is facing upwards completely. It should be directly on top of the two teeth. Stretch the belt using the roller brush as leverage down into the agitator housing of the vacuum cleaner, making sure that the two teeth are facing downwards straddling the little groove. After the brush is back into the vacuum cleaner, take the metal actuator arm from the rug / floor switch, and insert it back into the metal ring (or hole) on the roller brush;
Chris Jones
7helpful
Shark v1510 How do I replace the belt?
remove the outside sliding cover... remove 2 screw in from of housing, and also the screw holding the wheel on the brush head cap side of the housing. Once screws are rmoved, you can remove brush head cap and belt cover. Pull down on belt cover to remove. It is held by screw crossing the top of the cover from the side. Belts are hard to find, but can be ordered from shark web site (2) for 7.95 and shipping.
I had the same problem. Some one should stock these belts in the states, because Shark outsources thier call center to India, which sucks. It took 20 minutes on the phone to communicate through the noise and language barrier just to order a belt!
Oct 23, 2009 • Vacuums
5helpful
3answers
Changing Belt on Riccar 8650
Chris J.
6helpful
2answers
Riccar 8700 Brush Roll
Greetings,
I hope that this repair solution is helpful to you in installing the belt properly. If you found this helpful, please be sure to click the Thumbs Up Icons in the lower right hand corner of the solution. Feel free to request a clarification of the repair if you have any questions about this repair, or other repairs. I'm always happy to answer any questions.
Chris Jones
Top Shark Vacuums Experts
vince
Paul Carew
Are you a Shark Vacuum Expert? Answer questions, earn points and help others
