SOURCE: IR 2475E Wont start up 220 everywhere No LOP switch
did you check for a motor reset button on the motor??
SOURCE: My compressor 2475 ir (5hp) has no dip stick or
In the owners information your compressor takes the 1 bottle of IR oil that comes with it. If you have a local tractor supply company or another company who carries IR you might check with them, it is the only oil i would recommend for your unit.
SOURCE: I believe that the motor
You should not be pulling over 30 amps. If you are you may have low voltage, incorrect wire size or to long of a run for wire size. I would use a hand held meter and check the amps at full load.
SOURCE: All three of my capacitors blew in my IR T30. I
Hi, my name is John. Welcome to FixYa. Both of the black wires go to the + side on each capacitors, and the white wires go to the - side of the capacitors. Thanks For choosing FixYa...John
SOURCE: I need a manual to rebuild a Type 30 Model 2475 ingersoll rand air compressor. Thanks
Dear Joe Bell,
This is Rodciel L. Camacho of VISMIN compressed air care center we are specialize in ingersoll rand air compressor.
You mean a overhauling kit?The part number of that is 34319469.
Hope i can help you..
