SOURCE: daewoo microwave kor-1b4h
the only way on these is to take the case off
WARNING : DO NOT ATTEMPT TO GO INSIDE IF YOU DO NOT KNOW HOW THE HIGH VOLTAGE WORKS OR THE COMPONENTS THAT HOLD HIGH VOLTAGE!!!
and never go inside with it plugged in!
SOURCE: daewoo KOR 1B4H microwave light
It probably is, but I cannot find your model number on the Daewoo website to look in the manual.
Please confirm and reply the model number .
SOURCE: how do i change the bulb lamp on a Daewoo KOC-875TSL microwave
If
there's no obvious removable cover over the bulb (most often on the
rear or side) and the owner's
manual doesn't address it, then disassembly will be required.
You'll need to remove the outer cover (wrapper) to get to the bulb.
Always unplug a
microwave before removing or installing any bulbs.
If
it's an over the range type, remove the vent grille across the top and
see if bulbs can be accessed there. There may be a panel on the bottom
covering the light(s), instead.
If not, chances are
you'll have to remove it from the wall, then remove the outer cover. If
so, the installation instructions are very handy, and it's best to have
two people since the microwave can be heavy and awkward.
If you don't have your
instructions, please reply back with your brand and model number.
Once it's out of the
wall, the outer cover (wrapper) will need to be removed, just as you'll
need to do on a counter top model.
On a
counter top model,
be sure it's unplugged, but otherwise ignore the instructions
above this paragraph.
See these links before proceeding:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
The
screws you need to remove should be pretty obvious, but a special
driver (such as a T20H type or GTXH20-100) may be needed.
Be sure to put all the
screws back in the right holes, since some may be special grounding
screws.
Bulbs can be had locally in most
grocery stores, hardware stores, home improvement centers, and big box
or department stores.
Many models use halogen
lamps. You must not touch the new one with your bare skin, as the oils
will shorten the bulb life.
We're
happy to help you with free advice and we'd appreciate your thoughtful
rating of our answer.
SOURCE: How to change light Daewoo KOR - 63F7
If
Always unplug a
If
If not, chances are
On a
counter top model,
proceeding:
The
screws.
lamps. You must not touch halogen types with your bare skin, as the
oils
We're
