Question about Frigidaire Refrigerators
Cold freezer/warm refrigerator
My Frigidaire Gallery model#FRT22RGCW4 top freezer is cold/bottom frigerator is warm. Could it be the defrost heater or t-stat?
    Problem Solver:
  • 9 Answers
Same problem with Frigidaire Gallery model#GLRT182SAW5 (dated 2002 on back of case)
Vents were blocked with ice. Vents (from top compartment to lower) located behind light. You can check by poking a chopstick up the (2) holes; be careful not to hit fan blades.
Solution:
- took freezer coil cover off in back; checked that defrost heater element was working (marked and rotated the timer in the hole next to light); checked that fan working. Found ice in the vents and defrost drip area. Got it out with hair dryer.
- cleaned compressor coils in back (check fan is rotating; also tweaked some of the compressor tubing bends to make them more smooth - read somewhere about a manufacturing defect ...); blew out drip tube from defroster while down there.
- Set the freezer control to WARM and the refrig control to COLD (THIS SHOULD IMPROVE AIR FLOW FROM TOP TO BOTTOM).
- Put thermometers in top and bottom. Checked that refrigerator cycles (not running continuously). Checked that cold air is coming down from (2) vents behind light.
OK: so far, so good. Lower compartment is 40 or under. Top is under 18.
CONCLUSION: Suspect marginal design. Had problems with another similar model where defroster ice doesn't drain correctly, pools and refreezes. Leading to blocked vents as well as blocked defroster drain and similar problem including dripping water from top to bottom and warm bottom.
MAYBE KEEPING THE FREEZER CONTROL AT WARM GETS AROUND THE PROBLEM?? ANYWAY, ITS WORKING FOR ME FOR NOW !!
Posted on Dec 13, 2008
  • Richard Eisenman
    Richard Eisenman Dec 15, 2008
    Solution:
    light and noted that it rotates through the cycle ...); checked that fan working. Found ice in the vents and defrost
    OK: so far, so good. Lower compartment is 40 or under. Top is under 10.
6ya staff
SOURCE:
Frs26zgh-frigidaire/ gallery,frig is'nt cooling at all- freezer is cold,but not freezing.
Wow I hate to see that because I have one. You must have a defrost issue. Look on the backside of the freezer for noticable frost. That is an indication of something in the defrost system failing. Defrost system consists of a defrost heater, a defrost heater termination thermostat, and a defrost control. The most likely suspect is the defrost heater termination thermostat. It's job is to shut down the heater when the area is warmed enough to melt frost on the evaporation coils. I fixed one today with a defrost problem just like yours
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Feb 07, 2013 | Frigidaire FRS26R4A Side by Side...
Frigidaire Gallery Warm Refrigerator Cold Freezer
Generally the thermostat that turns on and off the compressor is in the freezer and so is the coils. The control knob that is in the refrigerator section is just to adjust the air flow between the two sections. If the air flow is blocked you don't get cooling in the refrigerator section. This could be a bad fan motor not creating circulation, ice blockage because the defrost cycle is not melting away ice accumulation. If it's defrost problems it could be timer, defrost thermostat, or heater element.
Feb 29, 2012 | Frigidaire Gallery GLRT218WD Stainless...
Botttom will not cool but top cools
Do you see frost built up on back wall of freezer if so it is not defrosting and this is what needs to be checked, remove back wall of freezer and check these;
Defrost heater-- it usually is at bottom of the evap. coil, to check it remove wires to it ,use a meter set to the lowest ohms setting and check for somewhere between 10-50 ohms if that is what yours is its good if meter reads OL replace defrost heater
Defrost thermostat-- if clips to the top of the evap. coil and is metallic,round , about the diameter of a quarter with a plastic side with 2 wires coming from it(do not confuse it w.thermister),remove wires and check for ZERO ohms WHEN TESTING IT MUST BE COLD so check it when frost is built up,IF meter reading is OL (WHEN COLD) its the problem
Defrost timer or defrost control if has digital display to show tempature
check timer(it could be anywhere except in freezer) by turning till you hear a click,the defrost heater should come on within 5 minutes if the heater does come on the timer is the problem and needs to be replaced,if the heater does not come on the above mentions parts (heater/t-stat) will be the problem.
defrost control is hard for unskilled lay persons to check SO IF heater and defrost t-stat are good replace control
Hope this helps,
Gene
Aug 03, 2011 | Frigidaire Freezer GLRT183TD
Refrig not getting cold ......frigidaire side by side........6yrs old.....freezer temp is fine.......vacuumed coils and rear of fridge...cleared of all collected dust
when you open the freezer door do you hear the fan blowing,could have a bad evap fan motor,also remove the second bin from the bottom and touch the back wall,if there's snow or frost there you have a defrost problem,could have a bad adaptive defrost board in the fridge section or a bad heater,defrost thermostat,take off the back wall inside the freezer,melt out all the ice with hair dryer,check the heater with a meter and t-stat,you should change out the thermostat anyway,you can cut the wires close to the t-stat,connect the wires so you bypass the t-stat,if the heater doesn't come on change out the adaptive defrost board,i think you click the lite switches 5 times to make it go into defrost,if it doesn't it's probably the board,look at the tech sheet behind the bottom kick plate,hope this helps
Mar 20, 2010 | Frigidaire FRS26H5AS Side by Side...
My kenmore 106.5706 has good freezer operation but warm refrig side. Fridge bottom vent had ice buildup and there was also no air from the top vent. I unplugged overnight to let ice melt then reconnected....
Most times that is the first sign of a defrost problem. Yours has a electronic defrost control part number 4388932 inside the fresh food section that may be bad. Look in back of freezer is frost building up on rear wall. If yes we need to check the defrost heater, defrost thermostat and the defrost control board. Thanks, Sea Breeze
Dec 17, 2009 | Kenmore Refrigerators
Frigidaire Model FRT18L4JB1 frigerator not getting cold, the freezer is working fine.
check to see if freezer wall is full of ice if so you have a defrost problem timer,heater or limit switch
May 08, 2009 | Refrigerators
Freezer is cold, bottom compartment warm
check to see if if the back wall of the freezer is full of ice if so this is an automatic defrost problem
timer ,heater or limit switch
Apr 23, 2009 | Frigidaire FRT21H7AS Top Freezer...
Frigidaire frs26znhd1
you have a bad defrost thermostat or defrost heater the way to get to both of these is go inside your freezer section and take off the panel on bottom the defrost t-stat is on top of the coil clipped to the line and the defrost heater goes up under the coil
Sep 29, 2008 | Frigidaire FSC23F7D Side by Side...
Refrigerator and freezer not working good
drip tray usually located at bottom of fridge at rear.sounds like defrost timer is no good,some models can be manually manipulated its located at bottom front panel or at back of fridge,if this is the case defrosting the fridge results in operation o.k. for a short period then gradually dying again
Aug 11, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
Warm frigerator
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
if you already checked this and think it is a different problem then let me know, i will help you figure it out.
Mike
Jun 14, 2008 | Frigidaire PLHS237ZD Stainless Steel Side...
Refrigerators Logo
1,590 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Thomas F. Schneider
jasbo
jasbo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
