Question about Ryobi Garden
How much oil do i add to a qt of gas to get a 50"1 mix?
Want to mix a quart of gas an oil to get a 50"1
    Scholar:
    New Friend:
  • 75 Answers
TWO STROKE ENGINES REQUIRE A OIL TO FUEL MIXTURE TO RUN PROPERLY.THE MIXTURE CHART CAN BE FOUND ON A LOT OF DIFFERENT 2 STROKE OIL CONTAINERS.AND PACKAGING..ALWAYS PREMIX IN A SEPARATE CONTAINER.,SO THAT ITS MIXED WELL BEFORE USE..ITS CRITICAL THAT YOUR PREMIX IS AS CLOSE AS POSSIBLE TO YOUR ENGINES SPECS..BECAUSE IF YOU DON'T YOU WILL HAVE ENGINE FAILURE..AND ALWAYS USE A GOOD TWO STOKE OIL..
Posted on Feb 22, 2015
6ya staff
SOURCE:
How much oil in a 2012 fat boy low ?
2013 Softail
a. Use 3.5 quarts (3.31 liters) of engine oil for a wet
capacity refill.
b. Use 4.0 quarts (3.79 liters) for a dry capacity refill.
NOTE
Use wet capacity values for engines that have just had
the oil drained. Use dry capacity values for engines that
have been disassembled, cleaned in solvent and dried.
2013 DYNA
a. Use 2.5 qt (2.4 L) of engine oil for a wet capacity refill.
b. Use 3.0 qt (2.7 L) for a dry capacity refill.
2013 Touring
Initially add 3.0 quarts (2.8 liters) of engine oil
2013 VRSC
Oil capacity with filter 5.0 qt 4.7 L
2013 SPORTSTER
Oil tank with filter 2.8 qt 2.6 L 2.8 qt 2.6 L 2.8 qt 2.6 L
Sep 04, 2014 | Motorcycles
How many ounces of oil do I add to gasoline to get a 50 to 1 mix?
Quite simple if the mix says 1:50 ( one to 50 ) ,it means for every one ounce of oil you add 50 ounces of gasoline.
If the instructions say 1/50 ( one of 50 parts) ,it means for every let us say 50 ounces of mix there are 49 ounces of gas and one ounce of oil.I use a one liter wine bottle !000 ml ,I put in 20 ml of oil fill bottle with gas and shake well-ps (mark bottle -hate to take a swig).If you are into avoirdupois system use 1 ounce oil add 50 ounces fresh gas .
Jul 26, 2014 | John Deere 2 Cycle Stroke Engine Motor Oil...
Gasmixture for 9.9 Mecury outboard
your safe to mix 50:1 , it is 50 parts gas to 1 part oil, or 1 pint for every 6 gals gas, 89 octane, TCW3 O/B oil, also add some stabil
Feb 19, 2013 | Boating
How do I mix the gas/oil on my farmtouch chainsaw
Most persons use a 50:1 mixture of gas to oil.
That means put one ounce of oil into a quart and a half of gas.
Or two ounces into 3 quarts of gasoline.
Or, a little over two ounces into a gallon of gasoline.
Aug 29, 2011 | Husqvarna Garden
How much antifreeze should i put in radiator after a flush
sytem capacity is 8.6 qts. you want a 50/50 solution, so drain alittle more than a gallon of the straight water out, and add 4.3 qts. of dexcool antifreeze or equivalent. i always go slightly stronger just to be sure, but not too much antifreeze as it doesn't work straight. no more than 4.5 qts.
Dec 22, 2010 | 2003 Pontiac Sunfire
2.2 4cl what wt. oil----is there anything to quiet lifters---140,000 miles---my friend said 1/4 qt transmission fluid
Transmission fluid will clean out the engine but then I suggest using 3 quarts of 5w/30 and 1 quart of 20w/50 at your next oil change.
Jun 04, 2010 | 1992 Honda Accord
First time to add gasoline, I am not sure how to mix oil and gas for ECHO PB-2100 ratio 50-1
50:1 means 50 parts gas to 1 part oil
you can mix a quart of gas with 1.5 oz of 2 sroke oil
May 06, 2010 | ECHO, Inc. PB-251C Handheld Blower
Ryobi PSC 3046y3e 30 cc petrol strimmer ratios of petrol to oil
WELL IF THERE IS NO 2 STROKE OIL TANK THEN YOU MIX IT WITH THE GAS. THIS IS HOW THE ENGINE GETRS ITS LUBRICATION AND WILL BLOW UP AND SEIAZE WITHOUT IT.MOST OF THESE SMALL ENGINS RUN AR 20 TO 1. OUTBAURDS RUN AT 50 TO 1. IF YOU PUT TO LITTLE ITS NO GOOD AS MENTIONED ABOVE. IF YOU [PUT TOO MUCH IT IS NT AS BAD AS IT WILL SMOKE A BIT AND POSSIBLE FOUL THE PLUG AFTER A WHILE. I WOULD GO WITH 230 TO ONE THAT WOULD BE 20 PARTS GAS TO 1 PART OIL 20GAL GAS TO 1 GAL OIL IS THE SAME AS 5 GAL OF GAS TO 1 QUART OIL OR 2 1/2 GAL GAS TO A PINT OIL OR 1 1/4 GAL GAS TO 1/2 PINT OILM GET THE PICTURE NOW. ITS DIVISION. AFTER A WHILE OF RUNNING IF IT SMKES AND THE PLUG FOULS JUST ADD A BIT MORE GAS TO YOUR MIX AND CLEAN THE PLUS WITH AN OLD TOOTH BRUSH AND I ALWAYS MARK MY GAS CAN WITH BLACK MARKER OIL/GAS MIX 20:1 OR WHATEVER.
REGARDS, PAUL
Jun 20, 2009 | Ryobi Cultivator
All fluids, tires, etc, checked out.
The check engine light doesn't monitor those things, it's an emissions warning. monitors a host of things that are emissions related. You need to have it checked by a technician. The most common cause is a loose (or defective) gas cap. Make sure it clicks when you fill up. As for being 1/4 qt low on oil, don't add that small of an amount. Only add if it's a full quart low. If you check it soon after the engine has been running it'll show low because there's still a lot of oil upstairs in the engine. The dipstick measures what's down low in the oil pan. Also don't add anything to the radiator; only add to the overflow jar. It's marked high and low; those are actually temperature dependent marks, it should be at the high mark when the engine is warm and low when the engine is cold. Coolant expands and contracts with temperature. Don't add straight H2O either; that should be 50-50 coolant/water. They'll do that when you get the oil changed.
Jun 10, 2009 | 1992 Buick Regal
Well since it's a 4 stroke I can't mix it with the gas. I drained out all the old oil and I just need to know the correct porportion of oil to re add to my bike
The proportion is 100% oil, don't mix it with anything. Put in two quarts, stand the bike straight up and check the oil. Add one half quart at a time until it registers full on the stick or in the sight glass.
Mar 09, 2009 | 1991 Yamaha XT 600 E
Garden Logo
375 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Dennis Tokarzewski
Level 1 Expert
Wayne McNeil
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
