Uniden Dect2188-3 Dect 6.0 Cord/cordless Combo Phone W/3 Handsets, Answering Logo
A
Anonymous Posted on Feb 22, 2015
How do I find messages/mute?
USING THE ANSWERING SYSTEM I NEED TO FIND MESSAGES/MUTE ON THE BASE
Level 3:
One Above All:
The expert with highest point at the last day of the past 12 weeks.
Top Expert:
  • Uniden Master 102,366 Answers
  • Posted on Feb 22, 2015
Uniden Master
Level 3:
One Above All:
Top Expert:
Answers
102366
Questions
0
Helped
10442133
Points
622693
To hear your messages, press PLAY on the base.
To mute, press CLEAR on the base.
See pages 22 and 6 of the manual: Owners Manual User Guide for Uniden Dect2188 3 Dect 6 0 Cord cordless...
How do you mute the answering system
You may be able to tap the messages using the handset instead of the base unit. That way you can listen to the messages discretely.
How to check voice messages from coreded base L702c model, or how to turn answering options on from the base unit
Hi, in idle state, from base unit press cassette icon botton (mute), the messages will be played from newer to older.
1helpful
How can I get my Uniden Answering Machine Dect 6.0 to get messages?
You may be subscribed to a voicemail system provided by your telephone company. Please contact them for instructions on accessing their voicemail system.
DECT 1480-4 Uniden Corless phone- how do you get rid of red LED lite ?
Do you mean the status light on the handset or the one on the base? The status light on the base will be on if the answering system is on. The handset status light will be on but steady when the handset is on the charger. (It's a battery charging indicator in that case; take the handset off the charger to stop the charging system. It provides a trickle charge to offset the battery discharging over time) The light blinks to indicate new messages are available on the answering system. Press the Play button on the base or the Messages/Mute button on the handset to play new messages.
Uniden offers the manuals for many of their phones on their support site: http://www.uniden.com/bin/venda?ex=co_disp-view&bsref=uniden&scat=dectphones_mnl . The direct link to the manual for the DECT-1480 is http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/DECT1480-2om.pdf .
I hope this helps.
1helpful
2answers
I AM UNABLE TO RECORD A PERSONAL MESSAGE ON MY DECT 1580. THE INSTRUCTIONS ON PAGE 11 STATES "1. SELECT COMMAND 8:RECNEWGREETINGS (RECORD NEW GREETING." WHERE IS" COMMAND 8? OR HOW DO I...
On your handset, press the Mute (the button also has an envelope to indicate messages). Press 5 on the handset to stop the playback of messages (if any are on the machine). When the handset beeps, press 8 on the keypad of the handset. When you hear "Record greeting", then speak your message. When you are done, press 8 or 5 to stop recording.
Note the answering machine must be on before you start. Press the On/Off button on the base.
I hope this helps.
5helpful
2answers
How do i set the answering system on a uniden 1580-3 phone, mine is just background noise on the answering machine when someone calls in to leave a message
Here is the manual for your phone. You can download the manual and the instructions for setting up your answering machine are on page 43:
http://www.uniden.com/pdf/DECT1580-3om.pdf
Setting Up the Answering System
You can set up your answering system's features from the handset. Only one handset at a time can access the answering system menus.
Note: If you have multiple bases, select the base with answering system you want to access (see page 15).
Recording a Personal Greeting
Your answering system comes with a pre-recorded outgoing message or greeting that plays when you receive a call: "Hello, no one is available to take your call. Please leave a message after the tone." You can record your own personal outgoing greeting. Your recorded greeting must be between two seconds and thirty seconds long.
Press /mute. The system announces the number of new and old messages, then starts to play the messages unless it has no messages.
Press 5 to stop the announcements or message playback. You will hear intermittent beeps indicating that the system is in the command waiting mode.
Press 8 to start the recording. The system announces, "Record greeting." Begin recording after the announcement.
When you finish recording, press 8 again or press 5. You will hear a confirmation tone, and your recorded greeting plays back for you.
Selecting a Greeting
Once you have recorded a personal greeting, the phone automatically switches to your personal greeting. You can
also switch back and forth between the pre-recorded greeting and your own greeting at any time.
Press 6. The system plays the current greeting.
I just got the AT&T Digital Answering system 1739. Is there a way to mute the volume? Would like to be able to mute the volume so if we have company and chose not to answer the phone, our company...
You can't mute the volume with a single button like on a TV. All you can do is turn the volume down with the control on the unit. (Then, of course, you have to remember to turn it back up!) You can get the manual here if you need a copy.
1helpful
I lost manual. I need to know change message when will be out of town answering message.
announcement.
To keep this greeting: Do nothing..
To switch to the other greeting: Press 6 while the system is playing the current greeting.
Each time you press 6, the system switches between the pre-recorded and the personal greeting. The last
greeting you hear is used as the current greeting.
Deleting Your Personal Greeting
You can delete your personal greeting from the base. You cannot delete the pre-recorded greeting.
Press 6. The system plays the current greeting. Switch to your personal greeting if necessary. (See the previous
section to switch the greeting.)
While the personal greeting is playing, press 4.
The system announces "Greeting has been deleted," and switches back to the pre-recorded greeting.
The voice message waiting LED light flashes and there are NO NEW MESSAGES. I have reset by holding the mute/find hs key on the DCT756 base model. The flashing light will not go away. Any solution for this?
your phone may be equipped with voicemail call your own phone number to see. mine is and that is why mine flashes. and the answering machine does not usually work with voice mail. i'm not sure why but i always have voicemails and no messages on my answeriong machine.
2answers
21095GE2-a user manual
I have the manual and can scan or fax pages if you want. Contact me if you still need this at: [email protected]
My system just quit allowing me to listen to messages and all three batteries quit. I'll probably have to get a new phone system.
Let me know if you need handsets and cradles too, I have 3!
Judy
Top Uniden Lands Phones Experts
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
