These are self locking jaws and its done up too tight.
try undoing chuck by hand, then with a little more force wrap some cloth around chuck and try a pipe wrench around chuck.
make sure you turn the right way or you'll make it worse.
if no luck then take it to someone that works with tools and ask them to do it.
SOURCE: drill bit is stuck inside my makita drill chuck
Try using the low torque setting on the drill when reversing and something to assist you getting a better grip to hold the chuck from spinning when reversing. This may help.
Good Luck
SOURCE: how do you change the drill bit for a Ryobi?
My husband explained this, via phone ..... made it simple....... grab the silver ring area beneath the black top area where the drill bit is located. Hold the silver area firmly, while you twist the black top. You will see the release, then remove drill bit. Laymen's terms, but it worked!!
SOURCE: sds drill stuck in chuck
tap it lightly with a ball pin hammer, if that dosnt shake it out try opening it and useing something to push it through
SOURCE: chuckless drill stuck tight with drill bit in
if you trap the chuck in a bench vice or alike and then use the drill in reverse in short bursts until it loosens a good spray with wd40 will also aid the situation
SOURCE: Using Ryobi Hole Saws
Hello. Somewhere in your set you will find what is called an arbor. The arbor has a drill bit in it and the hole saws get screwed on to the arbor.
Regards, Joe
PS - kindly rate my answer. thank you.
