69737 just replaced bulb!
Your color is distorted because your color wheel is probably going bad. Try resetting all the picture values first. Sometimes they need to go back to normal when the lamp is changed. Lamps only provide white light and have no bearing on colors unless they are very dim. Also check your cables. a loose or bad cable can cause this as well. Lastly make sure your new lamp is made by Osram or Philips. knock offs wont work.
