UL means there is too much water in the wash tank. It will continue to run the drain pump u ntill the water level is correct. If it is not pumping out then there could be a problem with the pump, blockage or relay fault on pcb
The display of "BoF" on the display is simply a confirmation code to commence the next operation on the dishwasher. It is not a fault code.
Refer manual of a AMX model Hobart dishwasher. If your model is different the general codes are same.
Means the Antilock Brake System is disabled due to a fault. Go to AutoZone or similar and get the code read for free. 90% chance it is a wheel speed sensor. The code will tell you if so, and which wheel to look at.
p2 would mean your rinse thermistor is open or shorted. its located on top near the the right side, after the vac. brkr. part# is 328994. remove old, istall new . dont forget to vote,hope this helps , monomoy
It means that the final rinse thermistor is bad.Your not getting 180 degrees---right?Its located on the booster and costs about $65.I work for hobart.Any ?
