Check the light sockets on either side of the garage door opener and make sure there is no corrosion on the contacts. If you see some corrosion unplug the garage door opener and scrape off the contact. Give that a try and lets see what happens.
To
have your lights come on automatically when you walk into an open
garage, you must START with the lights ON. If you don't want that
feature and you want to turn it off, you must START with the lights
OFF.
To
turn the feature on, turn the lights on manually with the wall
switch, then press and hold the LIGHT button for about 10 seconds
until the motor unit light bulbs flash. Now, if the light bulbs are
on, manually turn them out and then walk out through the open door.
The light bulbs should come on.
To
disable this feature, start with the light bulbs OFF and everything
else is the same.
To
OFF.
To
To disable this feature, start with the light bulbs OFF and everything else is the same.
