I have thoroughly cleaned and gone over the vac, but it will not pick up any dirt on the floor or carpet. I have used the machine for sometime, so I am familiar with how to operate it.
Is the belt on the beater bar broken? You can check it by removing the screws that are on the bottom and taking off the plate. Look at the long bar that run across the bottom and there will usually be a belt that turns it. If that is broken it causes problems. If not the belt then maybe the filter. If you cleaned everything and you are sure there is no blockage you might just have to go out and purchase a new vacuum. You did not mention what model of vacuum it is.
