First. Fuel filter is always replaceable. There could be many possibilities why is acting like that: not running on all cylinders (bad spark plug, wire, coil, ignition module, carburetor or fuel injector), clogged fuel filter or water separator, failing fuel pump
Remove the front cover and locate the FILTER RESET button above the dust sensor level indicator lights. Press and hold this button for 3 seconds until the unit emits a beep and the REPLACE FILTER light goes out.
Your fuel filter may have gotten to the end of it's life and needs to be replaced. Start with the simple and replace the fuel filter, a dirty fuel filter will not set the check engine light to come on, at worst it's a weak fuel pump and that may need to be replace. Good luck and thank you for using Fixya.
the indicator light could be on the control panel inside the refr section if your controls are there, or it is most likely on the front of the dispenser panel. it only comes on when you draw water from the dispenser and thats when you will see it be green, filter ok, yellow, filter at 80% life, or red, time to replace the water filter. also you dont need to shut off the water when changing the filter as it is made with a shut off device in the filter housing already and is automatic. by the way filters are expensive, go online and check prices. google "water filters" and find a good price.
The light flashes after a certain amount of run time. It is a reminder to check the filter to see if it needs cleaning. Once you have checked/cleaned the filter and reinstalled it, press the filter button for 5 seconds and the light should go out.
