Forget checking the spark by grounding the plug to the engine. This is both dangerous and does not tell if you have enough spark under compression.
Start by performing a secondary compression check, without proper secondary compression, the unit will not start. You need between 115 - 165 psi.
If compression is good, check the spark with an inline spark tester. Set the gap on the tester at 6mm. If you have a blue / white spark, ignition is good. Make sure the ignition is gapped .20" from the flywheel, more or less will retard or advance the timing of the saw. Make absolutely sure you have the manufacturer's recommended spark plug. If it calls for a resistor plug, it MUST use a resistor plug to operate properly.
If you have compression and spark, check fuel supply. Rebuilding modern carburetors is not recommended. They have very small fuel flow holes (due to emission) Replacement carbs can be purchased for under $100.
SOURCE: husqvarna rancher 55 chainsaw having
You need to check that this machine is mechanically sound, remove the muffler and check the condition of the piston skirt through the open exhaust port, any signs of scuffing ( seizure ), and the cylinder will need to be removed to assess the damage
SOURCE: my husqvarna rancher 455 will
Hi
Make sure you are getting spark at the spark plug, to do this:
Remove your spark plug and check to be sure you are getting a bright blue spark at the spark plug.
You do this by grounding the plug on the head of the engine and pulling the crank rope while you are watching the plug for spark.
If you are getting a nice blue spark then skip A below and go to B.
A...If you do not get a nice blue spark then you may need to replace the electronic module and or the sparkplug.
Note: If you have to replace the module be sure to measure the position it is in, it is critical to starting.
B...Also take some fine grit sandpaper (not emery) and lightly sand the flywheel where the magnet is located to clean any rust or corrosion from the magnet area.
Then follow the procedure below:
Sounds like you have dirt/debris in your caburetor jets,fuel passages or a diaphgram that is becoming non-flexible.
Check/Clean/Replace your Air Filter, a dirty air filter can make your engine run to rich with fuel.
Note: ALWAYS USE COMPRESSED AIR TO CLEAN YOUR JETS AND PASSAGES, VERY IMPORTANT.
Note:Before you disassemble the carburetor:
Write down on a piece of paper or take a picture of how the linkage attaches to your carburetor for later reference when you go to reinstall your carburetor.
Mark each piece with a awl, or some kind of instrument that will make an alignment scratch before you disassemble the carburetor into separate pieces.
That way you will know which way it goes back together when you reassemble it.
Sometimes you can get by with priming the carburetor or by using starting fluid and letting it run a few times like that, and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Be sure to check your fuel tank for water and dirt/debris, if there is water/debris then you need to clean your tank.
Check you fuel line condition after a while they will degrade and need replacment.
Check/Clean/Replace your fuel filter if you have one, normally they are located in the fuel tank of chainsaws and weedeaters.
When you remove your fuel lines from the carburetor be sure to make a drawing to how the lines are connected to the carburetor or take a pictue for later
reference.
Normally the big line will be the line the fuel filter is connected to inside of the tank.The smaller of the two lines is the return to the fuel tank from the carburetor after it is pumped thru the carburetor by the primer bulb.
Make sure you are using fresh fuel...and oil mix if your using a two cycle chainsaw or weedeater with the oil to the right mixture and not too much oil as it can cause hard starting.
If the mower/trimmer is over a couple of years old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
The diaphgram may look good and flexible, but it can be deceiving and not act as a fuel pump as it should because it has become too hard and will cause hard starting,start and run and shut off, etc.
When you clean your carburetor, I recommend that you use a laquer thinner type cleaner to clean and dissolve the laquer build-up in the float and needle jet passages.
Be sure to remove all plastic and rubber parts before using the laquer thinner because it can dissolve the plastic parts and render them unuseable.
Be sure to use COMPRESSED AIR to blow out all the fuel and air passages.The higher air pressure is needed to blow some of the trash/debris from the fuel or air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Keep in mind that the float (if you have one) for the carburetor must be level when you go to reassemble the carburetor or follow the instructions you get with the carburetor kit, or you could also ask the parts man that you get your kit from.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their original position before you started.
Note:
The little spring inside of the carburetor goes under the float arm.
That is where your fuel inlet needle/float valve is located...on the arm at the end.
Normally there is a small indetion in the carburetor base and a small protrusion on the underneath of the float arm where the spring will be in the right postion for installation.
The spring will set in the indention and you will install the float arm with the needle/float valve and float rod into position over top of the spring,you will push down until it is in position and then you can tighten the screw that holds the float arm assembly in position.
Once you have your carburetor cleaned/rebuilt that should solve your problem.
Please take time to rate me thumbs up
Hi Angela keeler, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? Please add make and model as it makes answering the question easier. There are a lot of saws out there and it is a lot quicker if we identify it immediately.
A saw needs 3 basic things to run. fuel, spark and compression. Is there a spark when the saw is pulled over.? Is fuel getting into the cylinder from the carb.? And does the saw have 'compression' when its pulled over.? Check these things first and give as much detail as to can
