Http://www.nikondigitutor.com/eng/d60/index.shtml
the digital tutor for the d60 should be able to help you.
Thanks,
Lee
SOURCE: Shutter speed and apertue not working for Nikon D60 Digital SLR
What about other modes?
Can your camera still take photographs?
You can Try the following;
Remove the batteries , as also remove the memory card. wait for about 5 minutes. Then install the only the fully charged batteries and restart the camera. Try to use the shutter or Aperture mode, hopefully, you turn it on it and should come back to life.
If not, then it best to show to the nearest Nikon service center..
please do rate this solution and thankss for using FixYa!
SOURCE: i use first time nikon d60.
it would depend on the lighting. you can lower down your shutter speed, or change the white-balance or aperture on the camera. make sure that your camera is set on manual. hit me back on the results.
SOURCE: Nikon D60 highlight
When you have the flashing highlight areas, press the down arrow on the command dial and it will scroll through various playback screen options until you get to the screen you prefer to view.
SOURCE: What is night mode on a Nikon d60. How do I turn
Night mode?
Do you mean Night Portrait mode? Select it by turning the mode dial to the appropriate icon, deselect it by turning the mode dial to some other mode.
Do you mean flash? It pops up automatically in the point&shoot modes (except for Sports, Landscape, and NoFlash). You have to pop it up in PSAM modes.
SOURCE: Will the Nikon SB600 speedlight
Yes. The SB-600 instructions don't mention the D60 because the SB-600 came out before the D60 existed. Bear in mind that the D60 does not have a commander mode so you can't use the SB-600 as a slave.
Basically, as far as the SB-600 instructions are concerned, just pretend that you have a D40.
