Washing Machines Logo
f
fiona Posted on Feb 19, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi i have Electrolux washing machine model EWF14811 the display is not working what can i do ?
Display is not working what do i do? no lights
Dado
Level 3:
Master:
  • Electrolux Master 511 Answers
  • Posted on Oct 05, 2015
Dado
Electrolux Master
Level 3:
Master:
Answers
511
Questions
0
Helped
482652
Points
1313
I've never seen a model EWF14811 so I believe that it is a EWF1481 model washing machines.
Unfortunately, you have to replace the entire electronics because the LCD display is part of the PCB.
Also, before replacing I suggest you to check contacts on the LCD display which can be weakened by moisture,... etc.
Dado
5 Related Answers
Anonymous
  • 4 Answers
  • Posted on Aug 19, 2009
SOURCE: unusual display on panel (padlock) machine can't be programmed door is not locked however
i just went through the same thing.......you need to hold the option and extra rinse buttons simultaneously for 6 seconds, this will unlock it.....so turn the machine on and press the two icons, dont worry about the beeping and flashing after 6 seconds the padlock symbol will go and you can use the machine as usual.....i wish they put that 'minor detail' in the manual...cheers!!
Anonymous
  • Posted on Feb 21, 2010
SOURCE: LG wash machine # wm 2277 hb front loader display flashes LE wont
We had the OE message come up and did the above procedures...that didn't fix it. I removed the dual pump modules (they come off in one piece...one is the recirculating pump, the other is the drain pump). Turns out, the drain pump impeller design sucks. Even though it turned when I put power to the pump, that doesn't mean your pump isn't bad. Once it is under load pumping water, the impeller can slip where the pin connects to it from the motor. We replaced the motor for $60 and that fixed the problem. Our unit is at least three years old and we have a family of four, so it does get used quite often. Nobody told us about the filter at the bottom of the unit and I figure if we knew this ahead of time, we probably could have avoided the impeller issue...but it is still a sub-par designed motor/impeller. The new one I ordered looks like an updated design so I don't see this happening again. It is quite easy to remove and replace the pump, btw.
Anonymous
  • 174 Answers
  • Posted on Jul 24, 2010
SOURCE: A washing machine Electrolux EWF 1025 does not start up.
E50 is displayed if the there is no drum rotation. drum jammed not allowing motor to turn/ no circuit through motor(poss worn out carbon brushes) less likeley but poss short on motor relay on electronic board.
Anonymous
  • 4323 Answers
  • Posted on Jan 02, 2011
SOURCE: Electrolux EWF1074 washing machine When I
Hi
To remove this error please follows the steps given on page#11 of this user manual for your Electrolux EWF1074. Hope this helps...please post back for further assistance.
Daniel
FitzOriginal
Chris Hall
  • 842 Answers
  • Posted on Jun 23, 2011
SOURCE: Hi my washing machine Electrolux
Oddly, the main site I use to find error codes skips from E45 to E51, but 2 other sources I have seen say:
eE50 is a motor error code.check the motor brushes are ok and check the insulation on the motor as this will give you an E50 error code (as could a water leak, dripping onto the motor).could also be a faulty wiring loom to the motor or a faulty main control pcb
E50- Insufficient heating during wash phase Either the NTC sensor setting is incorrect, the heating element has failed, there is a wiring or main PCB fault
In other words, this is a fairly generic fault code I'm afraid. I would check the motor appears clean and dry, but beyond this, you will need to do a fair degree of fault finding
1helpful
My Electrolux washing machine is blinking red with no time separator, can you help diagnose the problem. my model number is EWM09312
Here are some steps you can follow to try and identify the issue:
Check the Door: The start button on your Electrolux washer may start blinking if the door to the washer is not closed properly. Try opening and closing the door again to see if the button stops blinking.
Error Code Display: If the light only appears red, you can try the following manipulation to display the error code:
Turn on your washing machine
Simultaneously press the start button and the one to its left, usually the "end of cycle" button
After a few seconds, the error code should be displayed
Service Manual: For a more comprehensive diagnosis, you might want to refer to the service manual for your specific model.
It contains a guide to diagnostics of electronic controls and troubleshooting based on alarm codes. ELECTROLUX EWM09312 SERVICE MANUAL Pdf Download ' ManualsLib
Technician may have to replace PCB.
Electrolux Washer Extractor W4600H. Washing machine not spinning.
Question edited for full make model (what it is) and English.
Question moved to better category.
Special problem for Indonesian machines
https://www.google.com/search?q=Electrolux+W4600H+not+spinning
Hi my Electrolux EWF1074 isn't working. The timer is counting down but there is no water in the machine. I tried resetting it but it didn't work. Could someone please help me. Regards Matt.
Rapid reading of alarms:
Press the START/PAUSE button and the nearest option button (4) simultaneously for at least 2 seconds: the LEDs initially switch off, and then display the flashing sequence indicating the last alarm.
ewf1074-2rgnvy5j4oifscmshudmmeh4-3-0.jpg After reading error code (look display) will be a lot clearer in which phase of the washing cycle has occurred or is happening malfunction.
New washing machine (electronic) compared to the old models (electromechanical) consume much less water, so it looks that your washing machine is working properly, otherwise it would be stopped. This will be confirmed if the display show E00 which means there is no any malfunction. Any other error code, for exp. E10,E20,E30, E40, E50...... means some malfunction.
Dado
Ld error on electrolux ewt606 How i can fix it
I've never heard for model EWT606.
So, generally speaking error code is displayed as a letter "E" with two numbers, or just two numbers. For exp. E10,E50,E60....or 10,50,60 depending of model washing machine. Some of them are equipped with display (they show E50) and some other only with LEDs diode (you must count number of flashes and color light, red and green).
Dado
My washing machine will not turn on.
I suggest you rapid reading of alarms.
  • Press the START/PAUSE button and the nearest option button simultaneously for at least 2 seconds: the LEDs initially switch off, and then display the flashing sequence indicating the last alarm.
  • To display the previous alarms, press the button to the left of the START/PAUSE button in sequence.
  • To return to the last alarm, press the START/PAUSE button.
  • The alarm continues to be displayed for the amount of time required, and then the display returns to its normal operation.
  • While the alarm is being displayed, the appliance continues to perform the cycle or, if in the programme selection phase, it maintains the previously selected options in memory.
Dado
E21 error is showing on my electrolux EWF14811 washing machine. What does this mean and how do I clear it?
E21 means a problem with the water draining.
Could be defective: drain pump, pressure switch, wiring, current leak between heating element and ground and finally main board.
Also could be drain filter or drain tube (kinked or clogged) and leaks from water circuit on pressure switch.
Dado
Electrolux EW1087 with error code e91
Communications error between main PCB and display board.
Possible causes: wiring, main electronic,display board.
Dado
My washing machine just turns white light on display but nothing to display and white background light also comes when i turn it 2 times on n off
Good Morning Friend,
I understand you are having trouble with the display on your Electrolux washer, model# EWX14450W. In researching your model number, I have determined that it was manufactured in the UK. I suggest contacting the manufacturer for further assistance. They should be able to point you in the right direction for having your display repaired. Hope this is helpful.
-Best Regards-
WP
Electrolux model eied55hiw no power or display lighting, or dryer light when door is open. Therm Limit ohms good. Any ideas from here?
check your terminal block for short if it checks ok then i would start at the control , check incoming voltage and voltage to your display , use the tech sheet to follow wires .
6helpful
EF 2 error is showing on my electrolux EWF14811 washing machine what does this mean?
it means that your using too much soap in your washer... the service manuel recommends that you reduce the amount of soap you are using.
Top Electrolux Washing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
