Lands Phones Logo
A
Anonymous Posted on Feb 19, 2015
How do I link handset to base after power outage CS6529-3
All 3 handsets say out of range or no power at base.the base is continuously flash answer on/off an in use at the same time.none of the buttons do anything it worked fine until we had a power outage.
VikingMatt
Level 1:
New Friend:
Problem Solver:
  • Contributor 6 Answers
  • Posted on Feb 19, 2015
VikingMatt
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
6
Questions
Helped
4143
Points
10
You set the cordless phone back into the charging base. After a few seconds (longer if in need of a charge), the cordless will register with the base establishing the connection required to place and receive calls.
  • VikingMatt Feb 19, 2015
I bought an extra handset to add to my ATT TL86109 base. I need to deregister the hand set. It just says "out of range or no power at base" need instructions for deregistering.
The extra handset for the TL86109 is the TL86009. The manual for this handset is on the accessory handset page: https://telephones.att.com/pd/379/TL86009-Accessory-handset-with-caller-ID-call-waiting ; see the Support & Manauls tab. The direct link to this manual is https://att.vtp-media.com/products/TL/TL86009/TL86009_CIB_i8.0_20170526.pdf .
Make sure that the base has power and is connected to a working phone (land) line. To deregister all handsets, press and hold the Flash (on the left below the volume buttons) on the base for about 4 seconds. You'll see "Deregister all handsets?". Release the Flash button. Press the Yes soft key (below the LCD screen). You should see the base LCD screen read "Please wait". The registered handsets should read "Out of range or no power at base" until the deregistration is complete. Then you should see the message "Press Hold on base for 4 seconds and then press # on the handset" on all the handsets. The instructions are on pages 11/12 (page 15/16 of the PDF) of the handset manual. They are also in the full manual for the TL86109 on pages 135/136 (141/142 of the PDF) available here: https://att.vtp-media.com/products/TL/TL86109/TL86109_CIB_i14.0_20170526.pdf .
I hope this helps.
Phone says no link to base reconnect to mainbase ac addapter
The instructions worked after the additional KX-TGA402N handset was fully charged and I kept pressing the menu/ok button of the additional handset to advance from initial settings to the handset registration mode.
How do register an optional accessory handset to my existing main base...
Power outage need to reset - blinks "CL"
remove the power adapter and remove the battery from the handset. Now replace the battery and power the base unit , place the handset on the base and select intercom or search remote.
The base unit must automatically set the frequency to mesh with the handset and handshake to connect.
Handset has message Out of Range even though it is fully charged on on the handset.
The handsets are reading out of range because they have lost connection with the base. This happens mostly during peak power demands or power outages, but can also happen when the phone is unplugged for any amount of time. This can also cause, at times, the answering machine to stop picking up calls. To remedy this issue, reset the phone system. Please follow the instructions below:
To reset the phone:
1. Disconnect the power adapter, phone line, and remove all batteries from the base and all handsets. Leave it disconnected for 30 seconds to reset the base.
2. Place the batteries in the handsets first and then plug in the power adapter and phone line. Do not place the batteries back in the base yet.
3. Put the handset in the charge cradle.
4. It may take up to 1 minute for the "Out of Range" to clear from the display.
5. Once the "Out of Range" is cleared from the handset place the back up batteries back into the base.
5helpful
Uniden Cordless Phone Model DSS7855. frequently fails to connect to an incoming call, with 'out of range' indication. The phone is less than 1 meter from the base station.
The handset/base keeps a record of who it’s registered to. The base also keeps a record of how many handsets are registered to it.
Using the de-register function on the handset deletes the handset from the base (decrements the count) and deletes the base info from the handset. All this requires that the base and handset can communicate with each other.
To remove the base data from a handset when out of range of the base, press and hold the ‘end’ button and the ‘#’ button simultaneously until the phone beeps. It will now be de-registered from the base.
However, the base will still have this handset in it’s record.
To de-register all handsets from the base, remove power and the base handset. Press and hold the ‘flash/find hs’ button while applying power. Wait for the beep and release the button. The charge light will now flash. Sit any handset in the cradle. When the flashing stops, all handsets are inhibited from connecting.
However, the handset still appears to be connected to the base unit. Pressing talk will give an ‘Unable to connect’ message. To re-register the handsets to the base, you have to de-register the handset first with the two button method.
Of interest, pressing ‘*’ and ‘#’ on the handset while reconnecting the battery is suppose to reset the handset. Doing the same on the base unit puts you in some sort of diagnostic mode. Press speaker to exit.
UNIDEN 5.8 GHZ CORDLESS PHONES
Registering Handsets to the Base
Whichever handset you choose to charge in the base is automatically
registered to the base. Any additional handsets must also be registered to
the base before you can use them.
Be sure both handsets are fully charged.
One at a time, place each handset in the base. The charge/in use LED on
the base begins to flash, indicating the base is registering the handset.
Wait for at least five seconds, then pick up the handset and press
[talk/flash]. If the display shows TALK, the handset is registered. If not,
place the handset in the base to try again.
Press [end] and continue with the next handset.
Note:
Once both handsets are registered, it doesn’t matter which
handset is placed in the base or the charger.
When you charge the handsets, Caller
ID summary screen and the name of
the handset appears.
This can be find from uniden website.
http://www.uniden.com/pdf/DXAI4588-2om.pdf
Top Lands Phones Experts
k24674
Are you a Lands Phone Expert? Answer questions, earn points and help others
