I want to configure the router for my network but it won't allow me to log in. After I enter the user name & password I get an error 71014 and I can't go any further. Any advice on how to rectify this?
The best way is to install an excellent Runtime Error 71014 Fixer which offers you absolutely professional service to eternally and efficiently fix the variety kinds of registry errors and runtime errors in your computer, besides Runtime Error 71014.It's also highly recommended that you use a 'registry cleaner' to fix any of the damaged registry settings that could be inside your computer as well. The registry database is a central storage facility for all the files and settings on your computer, and is also what your computer uses to help it recall many different functions & files that it needs to run. One of the most common causes of the Runtime Error 71014 is the way in which your computer is unable to read many settings that it needs from the registry, causing your system to run slower and with a lot of errors. This can be fixed by using a registry cleaner to repair the problems inside your system.
for more help visit CBR Tech Solutions
Reset the Router to factory defaults.
Suitable for: Wireless N300 Routers, Wireless N150 Routers, Wireless N750 Dual Band Routers, Wireless N600 Dual Band Routers
The default login username and password are both "admin". If you have changed the login password, there is no way to find it. You need reset it to factory default and configure it as a new one.
Directly press and hold the reset button on the rear panel with a pin for approximately 10 seconds when the device is running.
Release the reset button and wait for the device to reboot.
Note:
1. Make certain that the router is powered on before it restarts completely. 2. The default IP address is 192.168.0.1(orhttp://tplinklogin.net ), and the default login username and password both are admin (all lower case).
Let me know if this helps.
