Delta Machinery Delta ShopMaster DP350 12" Variable Speed Bench Drill Press, 500-3100 RPM, 1/3 HP Logo
J
Jerry Oppenheimer Posted on Feb 18, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What can be used as a replacement for discontinued pulley part 904163
Delta no longer offers a replacement for my broken pulley. What can be used in its place?
  • Chris House Dec 17, 2019
    The shaft on the DP350 and DP250 are a little bit of a weird size and just sizing up a replacement doesn't work - plus a standard pulley will eliminate the variable speeds as a reeves pulley is needed. Leneave Supply (leneave.com) has the best replacement at this time. My pulley just fragmented and found that people are havng a hard time finding a replacement. Good luck.
Dan Apthorp
Level 3:
  • Master 2,824 Answers
  • Posted on Feb 18, 2015
Dan Apthorp
Master
Level 3:
Answers
2824
Questions
0
Helped
889094
Points
7391
Take the old pulley to a shop where they sell pulleys and try to match it up. I did that with my lawn tractor and found one that worked.
Replace dp350 pulley
try a fitter and turner /machine shop. they can machine one for you as 4 the cost hmmm is your machine worth it . there are generic pulleys available they need machining to your required shaft size
regards pete
Feb 16, 2015 • Drills
Will a variable drive pulley setup from a Jet JDP 12 work on my Delta DP 250?
if its a press fit on the motor spindle the parts need to be the same specs ...accurately measure the diameter of the motor spindle.. pulleys are usually machined to match motor spindle ,, if your pulley has a bush it may have been reduced from its bigger size and i may not have enough info so i may be wrong.. pete
Apr 30, 2014 • Drills
Spindle Pulley replacement
I need a pulley a few years ago that I could not find till I found it on ebay.
Fix motor pulley on delta 46-715 type 1
Just make a quick google search. You'll surely find several suppliers.
Jun 07, 2013 • Saws
3helpful
2answers
Need replacement pulley for a Delta DP350
I had the same problem and searched extensively for a replacement pulley, but couldn't find one. I thought I'd try something else and began looking at Love Joy variable speed pulleys. They function the same way and are much heavier duty that the cast pewter used by Delta. The one problem, they are EXTREMELY expensive. Tried ebay and found a number of different brands and sizes. I recently found and purchased a Reeves variable speed pulley 850C 5/8" bore & 5" OD off of Ebay for just under $30. Well, the motor shaft is just under 5/8" but larger than 9/16" so I was going to use a metal 1/2" ID x 5/8" OD spacer as a shim and file the inside down to the motor shaft diameter, which would definitely work. Fortunately I had an old 1/2 HP motor from an old drillpress and it had a 5/8" shaft. Dropped the Reeves pully right on and mounted it on the DP350 and it ran like a charm. It's a little off of alignment and I had to cut a hole in the top cover for the Reeves pulley to protrude out an inch or so, but other than that it works great. My only fear is that the front pulley might explode now. Guess I'll have to wait and see. I'll bet there'll be a lot of searchers for a 5" OD variable speed pulley on ebay! Hope yours works as well as mine!
The variable pulley over the motor has come apart. how do I put it back together?
There is supposed to be a snap-ring with covering a cap with a spring that compresses the pulley and holds it together. Maybe one of those pieces has broken or is worn out. Most online repair parts places have an exploded diagram of all the parts and where they go so you can identify a replacement.
1helpful
Will Delta Belt fit Mastercraft Band Saw
If you still have the old belt, take it to a well equipped hardware or auto parts store for a replacement. If the previous belt is missing, you will need to measure the pulley 'V' width at the top of the 'V', the center to center measurement of the two shafts, and the outer diameters of the two pulleys. Hope this helps!
I need to know the price for this part No.905610 for a drill press 12inch DP 350 this part is damage along with the Motor Pulley part nos. 904166 and 904163
can you describe the part, the other part number you furnished are superseded with replacement parts and I can't find this one listed, let me know and I will try and help
8helpful
7answers
Delta Luv Crib Replace. Parts - 4XG lower plastic guide & 4XM steel peg
I went to the website www.deltaenterprise.com. You will have to have the country of origin, model number and the date of manufacturer or you can not get the parts. The phone number is 800-816-5304. I do not have fast you will get the parts. I called and did not have the country of origin so I will have to wait.
Top Delta Machinery Drills Experts
ADMIN Andrew
ADMIN Andrew
john h
Steve Pack
Steve Pack
Are you a Delta Machinery Drill Expert? Answer questions, earn points and help others
