This occured after replacing the governor springs. I have viewd countless utubes to check correct fitting. I have not stretched or shortened the springs (some utubes say 'Don't touch', others say adjust??). I adjusted the throttle cable to just above the point the mower cuts out. At the point the revs are way too high. The governor vane and the springs move freely.
SOURCE: up and down rpms
This is almost certainly due to lean mixture. If your carb is adjustable, back out the high-speed mixture screw 180 degrees.
If there is no adjustment, then either the main jet is still partially blocked, or the carb has internal corrosion (in which case, you will need a new carb - it's not fixable).
SOURCE: adjusting governor/throttle briggs and stratton
there should be a little screw to help adjust your idle try that..counterclockwise to add more idle, clockwise to slow idle..
Hi David Allen, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?What are your engine numbers and what was the part number of spring you replaced?
