SOURCE: Coloured lines on picture screen
I have the same issue, Although My camera is a samsung N46, It was working perfectly the night before, then my friend switched it on and it came up with a black backround and pink + purple vertical lines going through it.
SOURCE: fe-340 wont turn on
If the lens is stuck out, that either means impact or it got squished and messed up the lens mechanism. You can have that repaired.
SOURCE: My olympus FE 340 is
There are two possibilities for said problem, one is ccd imager chip failure that will be replaced and other is jammed aperture that is inbuilt in lens mechanism and lens assembly will be replaced.
In either problem, camera needs visual check of qualified tech, local camera repair shop will help you.
Thanks.
Testimonial: "Very specific suggestion. I will bring them to a camera repair shop, and be able to speak intelligently about a possible solution. Thanks!"
SOURCE: Can a broken view screen on an Olympus FE 340 be
Hello
OK, firstly, you will be able to to repair this LCD art your nearest service centre, or at the nearest camera repair store. The total repair cost including labour will cost round about $30. It should take under 2 hours.
Hope this can be of help.
Please be so kind to rate if you found this helpful.
Kind regards
Lock123
SOURCE: download driver olympus FE-340 digital camera
Please get it here then : www.olympusamerica.com > Home > Support www.olympus.co.jp/en/.../digicamera/qa/.../di000400e.cfm
