Question about Kitchen Ranges
What am I looking for
Mums cooker has been disconnected to have a new kitchen, electrician will not rewire the cooker as he says its dangerous, as theres no cover on the back of the cooker, to cover the wires, what is supposed to be there, cooker is 3 year old.
    Top Expert:
  • 76,177 Answers
Call any other to fix it.
Posted on Feb 17, 2015
6ya staff
SOURCE:
How do i coonect the cooker cables to this defy 621 stove.show me with the diagram
Call an electrician. You may leave it in a dangerous condition.
Mar 31, 2018 | Ovens
Whirlpool gold GU 1200 no power at all Is there a reset button? or a fuse?
Old or newly installed. If new it was probably just not properly installed, that is more likely then it being broken. Also, by code all dishwasher must be on a separate line from everything else in the kitchen but most contractors are not qualified electricians and put other items on the same line. Look for a blow out GFCI plug that shut power off to the dishwasher. You should also hire an electrician (try Angies List so you get decent one) to rewire the appliance to code if this is the case. Of course you did check the fuse box. Right? I\'d still check for thrown GFCI plugs first. The guy that built my kitchen did not do it to code either. There was a GFCI plug on the same line.
Sep 21, 2014 | Dishwashers
Correct cable size for belling cooker fitting
If this is a fan assisted oven then a 2.5mm twin and earth is sufficient, but please consult the manual and let me know the wattage, or contact a qualified electrician.
Nov 25, 2009 | Belling 335 Electric Kitchen Range
Stoves precision 1100 operators manual
I need to change the bulb in the fan part of my Precision 1100 Stoves oven but I have lost the manual. How do I get access to change the bulb?
Sep 15, 2009 | Stoves 1000DFDLm Gas Kitchen Range
Don't know what electricity supply is required
Emmet in luton: what fuse does a rangemaster 90 duel fuel need?
Apr 10, 2009 | Rangemaster Classic 90 (Electric) Kitchen...
Just bought wells fyer model # F-67
3 phase is VERY DANGEROUS, contact an electrician,
Jan 26, 2009 | Wells F-67 21167 Deep Fryer
Range master toledo 90
I would follow these requirements if I were you:
The cooker must be connected to the correct electrical supply as stated on the voltage label on the cooker (This is obvious so far!). It should be connected through a suitable cooker control unit incorporating a double pole switch having a contact separation of at least 3mm in all poles (This means one of those big red switches with "COOKER" written on them). The cooker must NOT be connected to an ordinary domestic power point. The cable size used should be between 6mm squared and 10mm squared twin and earth. Where the installation is protected by a 30 milliamp sensitivity residual current device (RCD Breaker), the combined use of your cooker and other domestic appliances may occasionally cause nuisance tripping. In these instances, the cooker circuit may need to be protected by fitting a 100 milliamp device. This work should be carried out by a qualified electrician.
Oct 28, 2007 | Rangemaster Toledo 90 (Dual Fuel) Dual...
Cooker stuck on auto
Comes on like this when switched on, hold down the left 2 buttons on the clock controls then whilst still holding them pres the right hand button
or manuals available here...
http://www.rangemaster.co.uk/index_Rangemaster_Manuals.htm
Sep 18, 2007 | Rangemaster Classic 110 (Dual Fuel) Dual...
Kitchen Ranges Logo
75 people viewed this question
Top Kitchen Ranges Experts
Marvin
Marvin
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
