It started but then gave a F7 error message
F7 or 7 times flashing
Flow meter failure
Symptom:
Water inlet valve (WV1) is switched on and the water indicator (WI) is on (level reached).
Reason:
Causation: Hose felt down and slipped the disc of the valve. The effect is a displacment of the valve tapped.
Dado
SOURCE: my whirlpool dishwasher is showing
f7 error codes on whirlpool normally mean you have a bad control board..
SOURCE: Whirlpool dishwasher ADP5962 F7 error code
emmanuelr is spot on with this advice. The dishwasherr had been idle for a few months so as advised disconnected and reconnected the connection to the water flow meter and job done. My friend you are a scholar and a gentleman thank you so much. You are not an apprentice to me.
SOURCE: Hi i have a Whirlpool adp 7966 dishwasher and it
do what i do and go to whirlpool web site and they tell me what the code is.adrian,,,,,,
Hi
This error indicates a fault with the water flow meter. F7 means inlet flow meter malfunction
Remove the left panel and check the flow meter, try to unplug it and plug it again.
If not OK, change the part, If you have checked the sump filter at the bottom of the dishwasher, then close the door and turn on the power. Then hold the start button with the + and - buttons under the LCD display, until the drain pump starts. This should then reset the dishwasher.
Pease get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
