Go to Control Panel, Hardware and Sound, Devices and Printers. Select "Mouse". Check to see what the settings are there and if you can reenable your device. It will probably be under "Hardware".
If that doesn't work, go to lenovo.com and download and reinstall the device drive for your touchpad device.
SOURCE: frozen touch pad
Hold down the [Fn] key and then press the [F9] Key to toggle touchpad on and off
On my Toshiba Satellite 1135-S155 Fn key is in the middle of Control [Ctrl] and Alt [Alt]
SOURCE: i need help disbling this touch pad
You need to look into the user information manual for that notebook to see if there is a disable function. If nothing else works, Place tape over the touchpad and that should help. Additionally, you can look at your mouse sensitivity settings in Windows under control panel and reduce the sensitivity of the mouse.
SOURCE: I want to disable my touch pad.
There may be an Fn-Key combination that allows you to toggle between ON and OFF. (maybe Fn-F9). The relevant key should have a picture of a touch pad.
SOURCE: I can't disable touch pad
There should be a touch pad icon in lower right where your tasbar is, right click for options to disable, if no luck! go into device manager, it will give a list of drivers, locate the touch pad, click on plus to the left and right click, there should be a choice to disable, click over that to disable.
