If you smelled a plastic burning smell you've burned some wiring somewhere. You would need to pull out the whole thing and start by looking at the back. I once had a dead mouse that had shorted across the relatively high voltage terminals common on most stoves. You should unplug the stove before doing anything like removing panels. Be very careful. Once you've found the problem you might need to call an electrician to fix it, depending on how brave you feel and where the problem is.
SOURCE: Gas stove top works, but oven does not.
The Kenmore 24-Inch Self-Cleaning Gas Oven 30472
features a low-maintenance self-cleaning feature and is offered at a
fair price.
Many retailers offer only a limited
selection of gas ovens for 24-inch cutouts, but Sears has a fairly good
number of models to choose from. And the 30472 stands out because of
the its price and the self-cleaning feature. Since most 24-inch models
are so similar, you'll want to make finding the best price your
priority.
The 30472 (Sears item 02230472000)
built-in gas oven offers a feature set that is typical of ovens in this
category. You'll find a modern frameless door design and a digital
display. Most all products offered today have a built-in clock and
digital timer, like this one. The interior light goes on automatically
when the door is opened. As an alternative, you can switch on the light
manually without opening the door. This allows you to take a peak at a
cake or other food without any heat escaping.
As is
typical, this model also offers a pre-heat signal. Unlike the ovens of
yesteryear, when the selected temperature is reached, this model will
alert you.
Offered here in white, this model also comes in black (30479), bisque (30474), or stainless steel with black (30473).
At an attractive price, the 30472 warrants some serious consideration because of the self-cleaning feature.
For more information:
Sears/Kenmore
3333 Beverly Rd.
Hoffman Estates, IL 60179
1-800-349-4358
www.kenmore.com
SOURCE: SMEG A21X-5 Freestanding Cooker: Main oven has smoke/fumes everytime its used!
usual cause of fumes is if the grill is in the oven, when for example a roast is done, fat spits onto the grill element and the circular element and smokes. if you leave it on, the smoke will clear. some ovens have a fat guard which clips over the grill in the centre of the back panel to prevent this.
to clean glass, just use scouring pads - glass is virtually impossible to scratch
SOURCE: Whirlpool oven door won't open.
You can try unplugging the over for a while and seeing if that helps. But if that doesn't help you will have to let the oven complete the cleaning cycle in order to regain use.
SOURCE: I used the oven at 425C for about 30 minutes,
your mostlikley correct on the buring wires. The only thing that can be done at this point is to unplug the machine and start tearing in to it to find the bad wires.
SOURCE: whirlpool gs445lems range - oven won't light
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
