Cars & Trucks Logo
b
brenda leitz Posted on Feb 16, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where do i find free wiring diagram for the tail lights and plate lights?
I may need to redo the harness
marlon faulkner
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jun 05, 2015
marlon faulkner
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
2083
Points
Loo
I chang the vvalavecover. Gastic and it won't start now
jack layton
Level 3:
  • Dodge Master 5,569 Answers
  • Posted on Feb 16, 2015
jack layton
Dodge Master
Level 3:
Answers
5569
Questions
0
Helped
2397679
Points
20059
I hope you can read wire colors, sometimes the diagrams are hard to read. Also, autozone.com has free wiring diagrams. You have to register your vehicle, it's free. Then click on vehicle repair guides, find the link for wiring diagrams. Also, bbbindustries has free wiring diagrams.
where do i find free wiring diagram for the tail l - 25436307-crmzqrz2rklne0mg4w1ift5m-3-0.jpg
Fixing lights on 2001 Pontiac aztek as parking lights, tail lights and license plate lights do not work
Do you know what a wiring diagram is ? How to use a DVOM - digital volt ohm meter to test automotive electrical circuits ? That is the way to find the problem . Free wiring diagrams here http://www.bbbind.com/free-tsb
Electric Testing Techniques You Need to Know
2answers
TAIL LIGHT WIRING DIAGRAM 2014 KIA SORENTO
Hi. Thanks for your question. For the diagram of Tail Light you can visit https://www.reliable-store.com and download the entire workshop manual. It has all the information along with the diagrams for better understanding. Good day!
1helpful
3answers
Is the plate lights on a different fuse from my tail lights on a 1995 olds cutless supreme SL? Where is the fuse located for the plate lights?
Should be on the same fuse. If you have no voltage to the tag light socket, check the wiring especially where it connects to the tail light harness.
1helpful
2answers
Tail lights work but why don't license plate lights?
The license plate lights have their own separate bulbs. If you are able to replace the bulbs, that may solve your problem. If not, you may have a loose or rusted connection to the plate bulbs only. If you are able to gain access, you may want to check the condition of the harness that supplies the power to the license plate portion. Good luck and have a great day.
Tail light wont come on
Look for short in wiring within the wiring harness. Had same problem and found 2 wires shorted together
Missing license plate wiring and complete assembly. How do I splice in to the trailer or tail lamp wiring? Off the "brown wire"? Is it really that easy?
These are the diagrams basically from the headlamp switch going back to the license plate lamps. The main splice after the headlamp switch going back is in the main harness near the warning chime module. If you need a larger picture or the entire outside lighting wiring, feel free to email me at [email protected] with all your vehicle information. Yes it is that simple by just splicing into the main rear light wiring at the brown wire. Hope this is what you were looking for.....
2helpful
I need diagrams for the fuse boxes in the dash and engine compartment so I can find the fuse/relay I need to replace. My dash lights, tail lights and windsheild wipers are out.
Hi
There are a couple of wiring diagram and manual available on the net. The relay you are talking about is the park lamp relay which supplies power to the tail lamps, license plate lights and both front and rear park lamps. If the park and plate lights are working the light switch, relay and supply power are good. You need to verify for a broken brown wire to the tail lamps (assuming the sockets, lamps and grounds on both tail lights are good) .If none of the lamps are working then the 15A fuse number 3, the light switch or the park lamp relay could be bad (note different contact in the main light switch work the other lights)
You can find a wiring diagram and component location at
www.autozone.com and http://www.pdfgeni.com/book/1998-ford-ranger-wiring-diagram-pdf.html
Let us know if you want something more else accept the solution.
Thanks for contacting fixya.com
How do you replace brake light
  1. Disconnect and isolate the negative battery cable.
  2. Lower the tailgate.
  3. Remove the two screws that secure the tail lamp unit to the cargo box.
  4. Remove the tail lamp unit from the cargo box.
  5. Disconnect the body wire harness connector from the lamp back plate connector.
To install:
  1. Connect the body wire harness connector to the lamp back plate connector.
  2. Position the tail lamp unit into the cargo box.
  3. Install the two screws that secure the tail lamp unit to the cargo box.
  4. Raise the tailgate.
  5. Reconnect the negative battery cable.
Tail lights dont work
Oh boy, Chevy uses 3 important wires to make up their tail light harness. Brown is used for your parking lights and yellow and green are your signal and brake light wires, yellow one side, green the other. You have some seriously crossed wires. Start with tracing the lic plate lite since that works. Make sure it leads into your main parking lights and the ground wires from these tail lites aren't cut. The lic place lite will work with just power because the body of the lite is grounded with the bumper. Then make sure that there is power to the signal wires. You can do this with a test light and the signal light switched on. You don't need anyone to step on the brakes since it's the same signal, only interepted. Most importantly, Remove the tail lites and check grounds!! Good luck
16helpful
2answers
Need wire diagram to hook up trailer lights, truck not factory equipped w/harness,
I'm assuming you're just going to splice into the tail light wiring so that's what these wire colors are:
at the tail lamp 3 way connector:
black and yellow = park lamp
dark green and brown = left turn signal
there should be another connector with violet and black wire for reverse lights.
the stop lights are turned on through the turn signal circuits.
Top Dodge Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Arnie Burke
Arnie Burke
Are you a Dodge Expert? Answer questions, earn points and help others
