Has top oven/grill and main oven.
SOURCE: leisure rangemaster 55 gas cooker
It sounds exactly the same as I am experiencing on my oven of the same model. My theory is that the full flame gas is controlled by a thermostat, and that this has broken hence why the oven only stays on preheat. This will be a matter of a replacement part. Most likely the thermostat is a bi-metal strip that, because it has heated and cooled so many times in it's life it has simply finally given up. Try searching online for the correct part and get a corgi registered fitter or another suitably qualified fitter to come and replace it.
SOURCE: high flames in oven
Flame saftey device control valve stuck in open position that why main gas is coming other wise flame should be max 2cm long after flame saftey device heat up and bellow expand and main valve should open
SOURCE: Oven burner flame is low
On top of that safety valve is a nut. Get a good fitting wrench. Turn on the oven and use that good fitting wrench on that nut. Turn it counterclockwise till the flame comes up about midways of the flame spreader. Don't get the flames too high. Midways of the spreader now. LOL
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
SOURCE: Stoves 720EF Top Oven Failed
there is a safety stat/fuse on top of the oven exterior i think you will find that it also has blown. Make sure you have isolated the appliance at the fuse board first though, Good Luck
SOURCE: Replaced gas safety valve, burner flame now too hot
Take a 1/2 inch open end wrench and tighten the orifice on top of the safety valve.Probably about 2 turns. Then adjust the air shutter to mostly open.
