Homelite Timberman 45 chainsaw runs fine but will not idle. Ideas?
Homelite Timberman 45 chainsaw runs fine but will not idle. What could cause the chainsaw not to idle? Clean, fresh gas at correct mix 50:1. Clean fuel and air filters.
im no pro but id start with the throttle stop adjustment and the low speed jet.
screw low jet in, till its fully seated, do not force it. then back it out 1 and 1 / 8 turns. this should get it running and ideling.
been out fighting 2 saws today,r+r lines filters one problem on 1 saw same went from 50/1 to 30/1 quit over heating and evaporating gas,, pulls easier fires an pulls chain well on big cuts//used 50on two cords cool day last year today 80+ over heated
It's a design flaw in timberman chain saws. After some hours of use, they develop a bad habit of not releasing the clutch drum completely. And that takes precious power away from the saw. If it becomes too tight, the clutch drum may over heat and cause the plastic enclosure to warp or melt down. After messing with this brake for months, I ended up completely removing it. Replacing it was not an option for me - there was nothing to replace - it is not the brake band that's bad, but the mechanism in the brake handle of this saw that is flawed. Overall, this chainsaw is very cheaply built - Homelite used waaaay too much plastic in it!
