Anyone try this repair kit from ebay?
http://cgi.ebay.com/DELL-W3000-LCD-TV-POWER-SUPPLY-FIX-KIT_W0QQitemZ220335740249QQcmdZViewItem
Yes I tried it and now I have nothing, not even a green light. So much for that. I have 2 of these sets. If you never unplug them from 110 I never have a problem. Un plug them and wait 2-3 days and nothing.
Any lawyers what to take this on?
I replaced the capacitors and the IC they sent in the repair kit. Now, the power comes on with no problem but the screen is dark (slightly illuminated). I can't get any menu to come up or self test pattern with no inputs connected. Just a dark illuminated screen. I rechecked all of the components and connections. No self test pattern.
Ontarff: May you please describe what problems you were having before installing that ebay kit? I'm thinking of buying the kit to repair my set since I just got one for free. My set mostly shows the green power light no problem, but the screen does not always fire up. It seems to work better when I use the main power switch to turn the screen on
Same problem.
This issue is a common,
but hardly talked about from LG. Your tv is probably 1 or 2 months out of
warranty, and now you're hearing a series of clicks. ... If you have the
courage to open the back cover of your tv, and you do "NOT" see any
bad (bulging ) capacitors on the power supply, then it could be the voltage
regulator. After weeks of fighting
with LG to replace my tv, i decided to fix it myself. i'm proud to announce
that my 50PK540 is now working. want proof? Take a look at the video i
posted on youtube, then you will have a better understand why your tv is
clicking... I'm also selling the repair kit for this power supply board on ebay
now. LG power supply Board model number EAY60968801. With anyone of these
PCB # EAX61392501/7, EAX61392501/10, EAX61392501/11, or EAX61392501/12
with the parts if this kit, I've also fis several 50PK750 models, Some clients
have send me their broken power supply board, so I can do the repairs. Please
Make sure that you've already gone through the process of troubleshooting and
testing your tv's power supply board before making any purchases.. I recommend
that you get a tv tech to check it out, because every tv is different. Email at
[email protected] if you have any questions.and watch the video: part 1
& 2
Repair kit on Ebay
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=200849231403
Youtube
video PART 1 & 2
http://www.youtube.com/watch?v=I9wF0OLyV0k
http://www.youtube.com/watch?v=vHrv5XaDULI
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Parts: http://interliquidparts.com/
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Replacement power supply module: http://www.lcdrepair.us/1800fp-power.html
Basic LCD monitor and TV troubleshooting guide: Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you. Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Please leave rating if it helps.
