Casio CTK-720 Electronic Keyboard with Stand, AC Adaptor and Instructional DVD Logo
A
Anonymous Posted on Feb 15, 2015
Got a used CTK 720 and it has no power. sugestions
Plugged in and replaced batteries
jeff chenault
Level 2:
Sergeant:
  • Expert 200 Answers
  • Posted on Feb 24, 2015
jeff chenault
Expert
Level 2:
Sergeant:
Answers
200
Questions
0
Helped
65396
Points
901
Try plugging in without the bateries...Also check your adaptor as well as your ac requirements on your keyboard..It specifically calls for a Casio AD-5 Adaptor.
  • 9V power supply; 850mA
  • Positive sleeve/negative tip This needs to match your adaptor Good Luck
http://support.casio.com/pdf/008/ctk_720_01_e.pdf
1helpful
My CTK 720 isn't powering on from the adapter anymore but battery power is working. I bought a new adapter but it still isn't powering on. Can this be repaired?
This could be a loose plug inside the unit or it could be a circuit that is bad. If the plug failed it is from physical damage from something like tripping over it or heavy use. That can be repaired by replacing the plug. If it is something like a component in the unit on a board then it becomes a little more involved.
1helpful
My Casio Ctk-3200 keyboard can't get switched on with the power line, but it works with batteries.
You probably have shorted out the power supply. Test it with an ohm meter for proper operation. If it's not working, replace it. If it is working, then the power supply board in the instrument is shorted and you'll need to take it in for repair.
How to fix ctk 7200 keyboard sdcard erorr
SD or SDHC memory cards must be between 2GB to 32GB
1GB SD card for earlier models or even 2GB SD formatted by earlier models are incompatible (folder structure has changed)
2answers
Computer does not have Ctk-720 driver
PC drivers available at Casio
http://support.casio.com/en/support/download.php?cid=008&pid=20
If you have a MAC google casio driver for Macs by 3rd party.
Can't connect my ctk-720 to my mac
The Mac needs the driver, and you may need to select it in Chooser as well. If it is not on the instruction disk, it should be downloadable from the manufacturers website.
My CTK-2000 Casio won't turn on. It's plugged in, and I've turned it on.
Does it have a rubber power on button? If ss, it's probably worn oujt. Replace it.
Dec 11, 2009 • Music
2helpful
Hook up CASIO CTK-720 to Imac with Snow Leopard (10.6.2) G-Band
Thanks Francois. This is good advice. It is posted in the problems and questions section of musical instrument repairs.
Nov 30, 2009 • Casio Music
20helpful
2answers
How can i connect my ctk-720 to my mac & the garage band application.
Just did it today. Hooked up CTK-720 to Imac with Snow Leopard (10.2.6) using GarageBand.
Steps: 1) Go to : http://code.google.com/p/casiousbmididriver/ 2) Download the CasioUSBMIDIDriver.plugin (see the two choices on the right side of screen) 3) Place the CasioUSBMIDIDriver.Plugin file into the MIDI Driver subfolder: Macintosh HD => Library => Audio => MIDI Drivers 4) Restart 5) Plug in USB cable, open GarageBand, turn on Casio 6) In GraarageBand Open New Project, Start by using Piano, Select Keyboard (command K) in the Window menu 7) You should see the keyboard being played on the screen.
PS: Thank you Francois Ferland.
Nov 28, 2009 • Casio Music
My ctk 2000 casio keeps shutting off
Replace the batteries and get an AC adapter for it! These do NOT work when voltage os too low.
Nov 21, 2009 • Music
No power is coming through to my CTK 611, bought a new power unit and this has made no difference
There is a chance that the jack that the power supply plugs into is broken loose or has bad solder joints to the circuit board. I am hoping that you purchased a direct replacement for the power supply.
Top Casio Music Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Casio Music Expert? Answer questions, earn points and help others
