When I press the sustain, the note does not sustain.
When I do not press the sustain, all notes are sustained.
Make sure the pedal is plugged in before you turn the keyboard on and do not compress the pedal until the keyboard is on. Good luck.
I have the same problem, But I have been using the same pedal since new. Infact it came with this pedal. Then suddenly it started doing this. Could I have changed soem setting by accident?
I have an mgear pedal and it just started doing the same thing...
You might not be using the proper sustain pedal. You might have to take the pedal apart and reverse the polarity on the cable.
Note does not sustain
