flexible wire outer case , bend the case and allow wd-40 to penetrate to the steel wire inside
plastic covered
allow the wd-40 to dun down the wire all the way throufg
replace the cables
The simple solution is the replaceable shear pins in the front auger have sheared. This is normal and protects the snow blower from major repairs. I suggest going to youtube and search "replace shear pins on Cub Cadet snow blower." There are a dozen videos that will help you troubleshoot and make the repair.
The cable from the speed selector to the back of the snow blower frame needs to be adjusted. Instructions are in any Tory-Bilt, Craftsman or Cub Cadet owners manual.
(32 degrees and above, 30w oil) - (32 degrees to 0 degrees, 10w-30) - (32 degrees to -20 degrees below 0 and beyond -20, 5w-20 or 5w-30) Cub Cadets call for a low ash oil. it can be purchased at any cub cadet tractor dealership.
That looks like a Cub Cadet part # for the Snow Blower.
You will absolutely need to customize a Belly bracket and Mule drive. Possibly find a Cub Cadet belly bracket and modify it to match your mounting points on the TY4000
