Question about Vantage 3000 Winch-ATV
My warn vantage 3000 will not spool in. solenoid clicks but motor does not turn. winch operates on out. use for snowplow, only a month old
Just pulling out some cable and trying multiple times to winch in, both with remote and regular dash switch
    New Friend:
  • 126 Answers
If motor runs in one direction motor is not burned out.
Solenoid clicks, solenoid is ok.
Most likely points on solenoid on one side. If you can get to it, then look at the points.
To check , reverse battery terminals then click. the reverse should work and the other not. This will prove the points are bad on one side. .
In that case, you have to take it apart put in new points or get new switch.
Posted on Feb 19, 2015
Anonymous
SOURCE:
8500lb. motomaster winch- pulling up dock when winch all of a sudden goes into reverse?? Could this be the hand-held or the winch itself? Runs off a marine battery with a battery tender
it could be either one will need to test the switch with a meter if it got hot use of power will heat up unit the switch can malfunction or the power circuit in the winch did the same --moisture also plays havoc controls check also that no water seepage from cable interfered with power
Aug 16, 2016 | Cars & Trucks
John Deere 2012 648g3 skidder winch will let out, when you try to winch in it will roll slack out of cable, but winch won't lock up and pull hard. How can I fix it?
if your saying that winch will take in and let out ok but wont hold a load in tension , then your winch directional valve or the winch motor is worn out and is allowing oil to pass right thru it regardless of it not being activated as skidder winches don't have a brake like electric winches do it uses the power of the oil locked into motor to hold a load ( that's also why id never stand under a load suspended by one !!!)
Nov 15, 2015 | John Deere Garden
Having trouble with my logging winch constantly pulling in.
service the clutch section of the winch as it appears that something is broken in that section of the winch
This situation is dangerous because if something happens, the winch cannot be disconnected or reversed immediately
May 25, 2015 | Cars & Trucks
I pinched my remote plugin cable and broke one wire. I spliced the wire and the winch still won't work. Is there a reset button or a fuse which may have shorted out? The winch is a m12000 from 1997.
Is the hot wire connected directly to the battery? Did you check to see if the wire is hot after you spliced it? There may be fusible link in the wiring or the wiring may be broken somewhere else. You can also try running a new hot wire from the battery to rule out a faulty winch. Trace the wire from the winch to its source of power, ie fuse box or battery
Aug 03, 2014 | 265072 M12000 Self-Recovery Winch -...
Electric winch
Is there a load switch on winch
Jul 13, 2012 | Electric Superwinch 12 Volt DC Winch -...
I have a 2011 rzr. the winch worked corretly the first time using it. Now when you push the out switch it goes in. Please help.
Sometimes the winch cable can become pinched or bind up in the spool. This will make it act like it is going in when the out position is pushed. Try hooking your winch up to a post and turning it to free wheel on the winch, then slowly back the RZR up about 10-20 feet. This should be enough to free up any spots in the cable. Turn the winch back in to operating position, and try pressing the in and out on the switch to see if operation is normal. Otherwise someone may have switched the cables going into the winch, 1 yellow and 1 blue. Let me know if you need any more help, Daniel.
Oct 10, 2011 | Polaris ATV
I have a 2011 Sportsman 550 EPS Touring (2 up) with a glacier 2 plow set up. I have used it only this winter and already bent the blow frame, worn out the blade guides (the pads that keep the plow edge...
Your picking the blade up too high. I forget myself and have done the same thing and also broken the winch cable. You have to make a consious mental effor to not over pick the blade! The true answer is a limit switch on the winch that cuts power when the winch hits a preset height.I have searched the internet and found that such a device does NOT exist! I may build on myself, I don't think it would be hard to do. ANYWAY THE ANSWER IS TO STOP THE WINCH BEFORE IT GETS TOO HIGH AND TRYS TO WRAP THE PLOW AROUND THE WINCH!
Jan 21, 2011 | Sport & Outdoor - Others
Can not pull winch cable out had to take cover off
The clutch knob on the side needs to be loosened up. Rotate this and the shaft will be free to pull the cable out.
Nov 10, 2009 | Master Lock 5400d: Portable Select Access...
Unit will not pull up the anchor
First, put a volt meter across the winch's power terminals to verify that the voltage is not dropping several volts when comanded to run, indicating a bad cable connection somewhere. Anchor winch's pull alot of current from a battery.
For a test, use car jumper cables from a good battery to the winch to see if it runs better.
Oct 18, 2009 | Boating
Spare tire winch
This unfortunately is a common problem, you will have to cut the cable and replace the tire winch, luckily they are cheap.
Dec 05, 2008 | 2002 Ford F150 Regular Cab
Vantage 3000 Winch-ATV Logo
767 people viewed this question
Top Warn Vehicle Parts & Accessories Experts
Herve Boissonnault
Herve Boissonnault
Bill Boyd
Derrick Schultz
Derrick Schultz
Are you a Warn Vehicle Part and Accessory Expert? Answer questions, earn points and help others
