Dual Electronics CECT P168 Cellular Phone Logo
Posted on Jul 08, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Only emergency calls on my unlocked CECT i68 3g phone.
I recently purchased an unlocked CECT i68+ 3g phone. When I inserted the sim card it shows only emergency calls are available.
Anonymous
Level 2:
  • Expert 148 Answers
  • Posted on Jul 08, 2009
Anonymous
Expert
Level 2:
Answers
148
Questions
Helped
39053
Points
421
This phone is a POS.  Sounds like it can't read the SIM card, and therefore only 911 calls are available.
2answers
How do get my phone off of emergency call
This is a normal behavior when a phone does not have a valid/working SIM card. Without a valid/working SIM card or even without a SIM card, the phone can still be used for emergency call.
I hope it helps.
1helpful
Sci phone works with sim but cant call out emergency calls only
You probably have the sim card in there backwards. Just got the same phone and that was why It was doing this.
1helpful
2answers
How to detect the sim card i put?
I guess your phone has not been unlocked yet. Unlocked phones do not have any specific carrier software and work with all GSM carriers. These include T-Mobile, Cingular and AAAA . Multi-band unlocked phones also will work with carriers in other countries.So I guess you need to unlock your phone so that u can enjoy in your country.
Hi my sciphone has worked realy well for 3 weeks went to make a call the other morning and got the message your phone has a block on it emergancy calls only
This means that either the sim card has become dislodged (try re-inserting the sim card)
Alternatively, you will need to call your phone company to investigate. Have your sim card number and details ready, as they will probably need those details.
Best of luck
SCI Phone i9++
This things happens to me the.. Check the sim if inserted correctly. If you use sim 2 card slot (bottom slot), the metal connector of sim should face up. When you make a call, be sure you press the sim2 call(P2).
If you use the sim 1 card slot (top slot), insert the sim in facedown manner. When you make a call, be sure you press the correct button for sim 1 (P1)
6helpful
2answers
Emergency calls only and not showing service provider
sounds like either your sim card isnt inserted correctly, or the slots arent turned on. sim card slot 2 is the slot closest to the phone, gold chip faces up, sim card slot one is slightly elevetaed off the phone, gold chip faces down. make sure it is inserted all the way down. perss fimly. then go to SETTINGS>DUAL SIM SETTINGS>DUAL SIM OPEN>CLICK OK. This opens up both sim card slots. after you find out which slot you are going to use, you can repeat these steps and only have opened the one you are using.
I purchased a unlocked cect i9 and it states to insert sim card how do i unlock phone?
This phone is NOT 3G compatible (it's just it's name ...) if your Tmobile card is 3G it will not work. All CECT phones are factory unlocked !
ATT with i68 phone
try puttin the sim card corectly, theres 2 slots they go different just check.
2answers
My i68+ says emergancy calls only and insert sims after it is in
Unlock code is 1122. But check to see if the sim is inserted correctly. Open both sim slots first. The bottom slot should have the sim inserted with the gold bars facing up. The top slot should have the bars on the sim facing down.
3helpful
3answers
Invalid sim
Ok, this sounds f**king stupid, but, try this
-Dial *#000#
-change the date to one in the past
-switch phone off then on
-change the date back to present
This worked for me.... don't ask me why i even tried this
Top Dual Cell Phones Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
john h
Are you a Dual Cell Phone Expert? Answer questions, earn points and help others
