if you have a problem getting digital channels (uk) find local channel number digital uk can help enter tuning menu go to manuial tune on tv or digi box. it will ask for channel number start with highest number pess ok or search repeat for each channel number normal 4or 5 depends on aera if still not getting all channels put aerial lead which come for aerial into tv bypassing any equipment such as vcr/dvd recorder then start again if still not all channels may need aerial upgrade .if yo get all channels connect vcr/dvd if some channnels disappear need to reset RF out on vcr/dvd remove aerial .connect vcr/dvd via scart reset RF out on vcr/dvd this can be found in vcr/dvd set up menu reconnect all leads should now work ok
Note do not set RF out to any digi channel numer
You can try the One-For-All universal remote, then program it to suit your device.
Tip:
Not all universals program all devices.
Ask the dealer at the store if you can look at the listing in the printed manual first.
Otherwise do web research before u buy.
The ROKU code listed on your tv screen has to be entered at ROKU internet link.Site will ask you for your code ,enter it on your computer.You we required to open an account they will ask you for info and your credit card number.Then it will recommend and ask what channels you want,some are pay channels like Netflix and HBO.Some of the pay channels have a free trial offer,if you don't want disconnect those pay channels before trial offer is over or they will bill you on your credit card.
If your camera CD installer is lost you can download installer in the internet. If you will what is the model of your cam you need to visit their official site seacrh the model of your cam and download the driver.
YOU HAVE A BAD TUNER OR RF INPUT. IF YOU CONNECT THE CABLE TO THE VCR AND THEN USE THE VIDEO OUTPUT OF THE VCR TO THE VIDEO INPUT OF THE TV YOU CAN USE THE TUNER IN THE VCR TO CHANGE CHANNELS.
Unfortunately there is no listing. I suggest taking a little time to sit next to the television with an notepad to go through each channel one at a time to label what stations come in on what channel numbers. Sorry.
I posted this earlier, however I believe it applies in this case to:
This can be any number of things, here is a possible listing:
1) No High Voltage (check the IHVT or the trippler)
2) CRT filament transformer winding open (check the windings that supply voltage to the CRT filaments)
3) Video / CRT socket boards bad (highly unlikely but check anyway)
4) High Voltage power supply malfunctioning (related to problem #1)
This
listing is a good starting point. I would suggest that you purchase a
schematic to aid in testing the voltages mentioned in the 4 steps
above. If you have a background in electronics then do the above, if
not please ask a qualified TV technician to perform these steps.
1. Manually scan all channels on your TV with your TV remote and write down the channels and network shown:
(sample: 119.2 C-SPAN2 digital channel).
2. Go to Edit Channels and find the icon for C-SPAN2 (about icon 261 in my zip code). Manually change the channel from Off to On, Insert the frequency, and optionally insert the number you want the channel to show in your channel listing ( or move it manually later).
I have about 10 to add each time I reset my recorder.
