Making sure theres no blockages
SOURCE: bosch exxcel 1200 express
need more info what point in the wash does it start to display the code
SOURCE: bosch exxcel wf02465 wont spin
We had similar problem, with the spin cycle not working. We opened the 'drain' pipe (front-right bottom side). It was full of lime scale; never been opened for years. We cleaned it up and the spin cycle is now working.
SOURCE: I don't have a User Manual for our Bosch Exxcel 7
I think you press and hold for ten secs to clear its a childlock
SOURCE: my Bosch classic 1200 express washing machine wont drain or spin
Possibly a blocked filter or pump.
Ths filter should be at the bottom right front of washer, sometimes behind a removeable cover at the bottom of washer.
To clean it, unscrew anti-clockwise, remove and clean.
SOURCE: bosch exxcel 1200 express fault code f04 what is
i had this problem,no drain or spin,opened the flap at bottom right hand corner and pulled out small hose to drain machine opened circular filter cover (some water may come out) and found a 5p and 1p blocking filter after removing ,machine worked fine.
hope this helps
