Apple iPod touch Logo
T
Terry batchelor Posted on Feb 14, 2015
I cannot sign into iCloud on my iPad or Facebook
I changed my password last night and today when I tried to sign in they kept saying password incorrect but they won't give me the chance to change it again
angel2726
Level 1:
  • Contributor 4 Answers
  • Posted on Feb 15, 2015
angel2726
Contributor
Level 1:
Answers
Questions
0
Helped
255
Points
Try signing in from a different device if that does not work,You may have to call them, it might lock you out if you attempt it too many times.
Not Pictured
Level 1:
New Friend:
  • Contributor 18 Answers
  • Posted on Feb 14, 2015
Not Pictured
Contributor
Level 1:
New Friend:
Answers
18
Questions
Helped
1458
Points
37
Try remembering any caps they are important.
The password is CaSe SeNsItIvE
  • Not Pictured
    Not Pictured Feb 14, 2015
When im trying to get apps and other things on ipad it always says my email is not reconizable and its a email is wrong
It could be your using your email password instead of your Apple password. They could be different. If you have a computer, go to iCloud.com on the internet and try to sign in the email address and password you use for your Apple ID. If it doesn't work, your password or Apple I'd is incorrect. You might try and select forgot password on the iCloud screen and correct it.
I forget my icloud iphone password
To recover your iCloud password, you can do the following steps on iPhone and iPad, which is the simplest way.
Step 1. Tap on your iPhone/iPad screen to open the Settings app. Then scroll down to tap on "iCloud".
Step 2. After entering the "iCloud" interface, you can see the option Forgot Apple ID or Password?. Tap on the option and you'll have two choices:
A. If you know your Apple ID (An Apple ID is the personal account you use to access Apple services like the App Store, iTunes Store, iCloud, iMessage, the Apple Online Store, FaceTime, and more. It includes the email address and password you use to sign in.)and cannot remember the password, then you can type in your email address and click "Next" to start the process to recover iCloud password.
B. If you forgot your Apple ID, tap on the Forgot Apple ID option and fill out the following information: Last Name, First Name and Email to recover the Apple ID, then click Next.
Note: You are supposed to answer all the security questions which is relevant to your Apple ID, and then follow the directions shown on the screen to complete the process.
After answering all the question, you can finally reset the iCloud password and then log in as usual.
For more details, check: How to Recover iCloud Password
1helpful
2answers
How do I reset my Apple ID?
Follow the following steps:
  1. Tap Settings > iCloud on your iOS device. If you see the option to sign in, you can change your Apple ID now.
  2. Scroll down and tap Sign Out. ...
  3. Choose Keep on My iPhone or Delete from My iPhone.
  4. Enter your password.
  5. Go to Settings > iCloud and enter your New Apple ID and password.
  6. Tap Sign In.
If you need need to reset the password, navigate to the follow link and click 'Reset your password': https://appleid.apple.com
How to unlock a icloud locked ipad
Step 1 Navigate to Apple's Find My iPhone page (link in Resources). Alternatively, if you have another Apple device, you can download and launch the free Find My iPhone app from the Apple store.
Step 2
Sign in to iCloud using the Apple ID associated with the iPad.
Step 3
Click "All Devices," and then select your iPad.
Step 4
Click "Erase iPad," and then re-enter your Apple ID password. Enter any phone number and message. This information displays on the iPad screen, and is normally used to help you recover your iPad if you lose it.
Step 5
Turn on your iPad, and then wait several minutes for iCloud to erase the information on the device. If your iPad uses only Wi-Fi, the device must be within range of your Wi-Fi network.
Step 6
Restart the iPad, if necessary, to bring up the Activate iPad screen, and then enter your Apple ID and password. The iPad opens to the setup screen because you erased all of your information.
Step 7
Tap "Set Up Your Device" to begin reconfiguring the tablet.
Step 8
Tap "Restore From iCloud Backup" if you have a backup of the iPad on your iCloud account. Sign in to iCloud again, if prompted, tap "Choose Backup," and then select the most recent iCloud backup to restore your iPad without the lock code.
Good Luck
How to reset password
If you forgot the password, you can refer to the below steps to reset the password.
How to unlock iPad screen without password with iCloud
You can also use iCloud to remove your password and recover your data if you have backed up before it was locked. And it is in the premise that you have set up Find My iPhone on your iPad, and you did remember your Apple ID, you can use iCloud to unlock your iPad.
  • 1. Open your laptop or computer, go to icloud.com/find or open the iCloud app.
  • 2. If the sign-in window pops up, just sign in with your Apple ID.
  • 3. There's an All Devices button at the top-left of the window, click on it to call out a drop-down menu and choose your iOS device.
  • 4. Click Erase (your device) in the prompt to finalize the process.
  • 5. Now you can either recovery data to your device from a backup or set up as new if there isn't any back-up before.
For more methods, check: How to Unlock iPhone
Private messaging
private message? Apple has never added a private message feature unless you are talking about iMessage. if iMessage is the problem then just check setting for messages in settings and sign in and if you are signed in then check if it says waiting for activation. if it doesnt say that then a restore would help or make sure that iCloud is set up right. a restore would be last resort
Iphone will not unlock
Did you mean forgetting iPhone password? If so, you can resort to iTunes or iCloud to unlock your iPhone. Just follow below steps to do that.
For more methods, check: How to Unlock iPad
Top Apple Audio Players & Recorders Experts
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
ZJ Limited
ZJ Limited
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
