Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
Posted on Jul 07, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Sears Model 3 41A4315-7D Have 2 remote controls and one keypad. I reset all the codes and I can follow the instructions and program one device, any other device will not program after the first device is programmed. The order with which I program the devices does not matter, only the first device programmed will work.
Anonymous
Level 3:
President:
  • Master 3,197 Answers
  • Posted on Jul 08, 2009
Anonymous
Master
Level 3:
President:
Answers
3197
Questions
Helped
1457995
Points
8183
You might try programming them this way if you haven't already.
Press and hold the button down on your remote and then press and immediately release the smart/learn button. Do this for both remotes.
Press and immediately release the smart/learn button and then walk over and key in your 4 digit code and press enter on your keypad.
What was the problem that made you decide to "reset the codes"? May be a clue to your problem.
Bought house with craftsman garage opener. Owner only had one remote. Bought a new remote at Sears that matched color code. followed instructions to code remote...that worked but made the old remote non...
Post the model number of the opener and the model numbers of the remotes. The opener model number is found on the end closest to the door and starts with 139.
Try programming the keypad like this:
Locate the smart/learn button on the rear of the motor unit near where all those white wires go. Press and immediately release this and then walk over to the keypad and key in any 4 digit code you like and press enter.
After programming the keypad see if either remote will work with it. Post this information also.
2answers
Garage door opener will not program the remote. After following directions on back of the opener the remote will not work. The doorbell button on wall the light keeps blinking. What do I do to fix this...
Reset both the units the door unit and the remote by cutting off supply for a while. Now it will move to the default settings. If the earlier process had hung the system then reset the codes given once again to allow the main control unit to lock on with the remote. follow as instructed till the remote locks.
If not contact the dealer as the main unit has some errors.
Trying to reset a new 4 digit code in my wireless remote Sears 139.53754 but I dont know the current code which the instructions say I need in order to reset. I tried the smart button on the motor unit...
You don't need the current code. What you need to do is press and immediately release the smart button and then walk over to your keypad and enter any 4 digit code you like. If this doesn't work your keypad is bad.
Programing garage door opener
Hold the button on the remote and press and immediately release the smart/learn button. Do this for each of your remotes.
For the keypad press and immediately release the smart/learn button. Walk over to your keypad and key in your 4 digit code and press enter.
If these instructions don't work you have a bad logic board.
4helpful
Can't reset remote keypad
Press and immediately release the SRT button and then walk over to your keypad and key in any 4 digit code you like and press enter.
1helpful
Can not program both keypad & remote to operate at the same time
One of your units has reverted from "rolling code" to "billion code" and as you have found they will each work but will not work with each other. The problem is finding out which unit reverted. The most common one is the hand remote but that could be wrong.
1helpful
2answers
Liftmaster 1/3 HP. Remote and wireless keypad stopped working.
Sounds like the reciever for you wireless devices is not working?
1helpful
Sears garage door keypad/remote programming problem
The button you added in your car is an earlier technology that is not compatible with the rolling code technology.
Programming remotes for garage door
sounds like you are doing keypad ok. is battery good. as far as homelink in car. follow directions for rolling code/security plus.
Liftmaster 724LM Pug-in Light and Appliance Control
does it have a learn button. push it and push remote button.
Top Sears Building Materials Experts
hsapiens
Level 1 Expert
Are you a Sears Building Material Expert? Answer questions, earn points and help others
