Here are some exploded diagrams that are on the Internet. Some may not be your exact machine so look carefully.
sears encore sewing diagram Google Search
SOURCE: Brother Window Matic Model HA3-B5
I believe this is the manual that you need.
http://gotoes.org/sales/BrotherSewingMachineManuals/ViewInfo.pl?Brother=1&Sewing_Machine_Model=window-matic
go to www.sears.pammar.net for a few bucks he will send you the manual in a pdf. format
[email protected]
SOURCE: brother sewing machine model XL-6562.needle holder came off rod.n
The needle holder has a screw right above the screw that holds the needle in place. It really doesn't look like a screw because it does not appear to have a slot for a screwdriver. However, with a small flat head screw driver you can tighten it up. There is also a curverd wire that must be inserted into a slot at the bottom of the holder. The screw tightens against the wire that tightens against the post. (It's a curved wire that curves around the front part).
