Brother DCP-1510 Laser Multifunction Printer - Monochrome - Plain Paper Print - Desktop Copier/Printer/Scanner - 21 ppm Mono Print - 2400 x 600 dpi Print - 21 cpm Mono Copy - 600 dpi Optical Scan - Manual Duplex Print - 150 sheets Input - USB Logo
Darai Bishal Posted on Feb 14, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How can i solve the error"toner ended" - Brother DCP-1510 Laser Multifunction Printer - Monochrome - Plain Paper Print - Desktop Copier/Printer/Scanner - 21 ppm Mono Print - 2400 x 600 dpi Print - 21 cpm Mono Copy - 600 dpi Optical Scan - Manual Duplex Print - 150 sheets Input - USB
David Payne
Level 3:
Top Expert:
  • Brother Master 14,162 Answers
  • Posted on Jul 15, 2015
David Payne
Brother Master
Level 3:
Top Expert:
Answers
14162
Questions
0
Helped
2998234
Points
455836
Lawrence Oravetz
Level 3:
  • Brother Master 10,558 Answers
  • Posted on Feb 14, 2015
Lawrence Oravetz
Brother Master
Level 3:
Answers
10558
Questions
Helped
2699897
Points
29284
Change the toner cartridge
DISPLAYED ERROR IS TONER ENDED HOW TO SOLVE THIS PROBLEM
I would believe you are talking about either a printer or copier toner. Either case you would need to buy a new cartridge to replace it.
Canon irc4580i print dark problem
In the process used printer, will be inevitable printed page by your printer have the bad quality prints. For example: Toner specks, Light image, Vertical line, Dropouts, background, Toner smear, Vertical black line and band, Vertical white line, Background scatter, Black pages, Loose toner, Horizontal stripes, Ghost, Uneven Density, poor fusing ...
The common print quality problem Canon IRC-4580 printer
Currently, The Canon IRC-4580 is the laser printer have high speed, easy to use, friendly for user and printing clear text.
However, we can not avoid the damage of some components of the printer when used.
In this article, I will introduce some basic errors with printing quality problems of Canon IRC-4580 printer and "How to fix it".
After viewed artical, you know:
- How to fix (repair/solve) Vertical line (black or white) in Canon IRC-4580 printer
- How to fix (repair/solve) Poor fusing (loose toner) in Canon IRC-4580 printer
- How to fix (repair/solve) Uneven Density in Canon IRC-4580 printer
- How to fix (repair/solve) Light image in Canon IRC-4580 printer
- How to fix (repair/solve) Ghost in Canon IRC-4580 printer
1. Fix print quality problem "Vertical line" for Canon IRC-4580 printer How to fix print quality problem Vertical line
This plobrem "Vertical line" is usally error of Canon IRC-4580 printer. For this "Vertical line" error, technicians divided into two smaller error are: Vertical black line and band and Vertical white line.
Description:
- Vertical line and band: On the printed image appear some straight thin black vertical.
- Vertical white line: On the printed image appear some white vertical voids.
Error location:
- Surface of the charge roller
- OPC drum
- Cleaning blade
- LSU unit
- Developing roller
Cause of error "Vertical line" on the printed page:
- May be surface of charge roller scratched or dirty by toner powder.
- May be have some grooves on the OPC drum.
- May be cleaning blade is damaged.
- May be LSU window or LSU lense has dirty.
- May be surface of developing roller has scratched.
How to fix(repair) "Vertical black Line and Band" for {{SPkey1}} machine:
- Replace the charge roller of toner cartridge.
- Replace the OCP drum.
- Replace the cleaning blade
If printed page are not improved
- Clean the LSU unit by soft cotton cloth and try to print. If Vertical line is not clear on the printed page you should replace LSU unit.
- Replace new axis developer and try to print
2. Solve print quality problem "Poor fusing (loose toner)" for Canon IRC-4580 printer. How to fix print quality problem loose toner
Description loose toner: Toner is not properly fixed on paper, use to hand rubbing lightly on the printed image toner powder may be stick in hand
Error location: toner cartridge or fuser unit
Cause of error "Dark Image or black" on the printed page:
When toner cartridge is empty. You toner refilled by toner powder ware not compatible. This is makes toner cartridge components demaged and temperature of fuser unit is not enough melt to toner powder
How to fix(repair)"Poor fusing (loose toner)" on the printed page for Canon IRC-4580 printer:
With this error, you should replace toner cartridge or fuser unit to fix it.
3. How to fix print quality problem "Uneven Density" for Canon IRC-4580 printe How to fix print quality problem Uneven Density
Description: The printed page has one half light and one half clear.
Error location: Toner cartridge, transfer roller, springs, doctor blade
Cause of error "Uneven Density":
- The pressure force on the left and right springs of the transfer roller is not even.
- May be toner low also causes this error
- Doctor blade has bent
How to repair error "Uneven Density" on the printed page for Canon IRC-4580 printer:
- Replace springs and transfer roller.
- Toner refill toner cartridge Canon IRC-4580 and reset toner cartridge chip (replace new chip) or replace new genuine toner cartridge.
- Replace doctor blade.
4. How to solve print quality problem "Light image" for Canon IRC-4580 printer How to fix print quality problem light image
Description: The printed image is all light and no Ghost.
Error location: Toner cartridge, Developer, HVPS board
Cause of error "Light image" on the printed page
- Enabled toner save.
- Toner cartridge is low
- OPC drum may be faulty by strong light intensity
- Temperature in room is below than 10*C
- Bad contact caused by the toner dirty between the high voltage terminal in the HVPS and the one in the set
- Abnormalities output from the HVPS
How to fix(repair) error "Light image" on the printed page for Canon IRC-4580 printer:
- Disable toner save by change in printer driver.
- Replace the OPC drum.
- Replace developer.
- After printer is power on, wait 30 minutes then start printing
- Clean up the contact between the high voltage terminal in the HVPS and the one in the se- Replace the new HVPS if the problems are not solved by 4 away above.
5. How to fix print quality problem "Ghost" for Canon IRC-4580 printer How to fix print quality problem Ghost
Description: Ghost occurs intervals of the OPC drum or transfer roller.
- OPC drum has fauty.
- The life of the transfer roller has been expired
- The high voltage terminal is contaminated by toner powder or
- Replace OPC drum
- Replace transfer roller
- If performed 2 away and the error does not clear, you should replace ganuine toner cartridge .
- Replacce HVPS board.
Error C7990
This error indicates that the waste toner area of the drum unit is full. One way to resolve is to replace the drum unit, power the printer on, and the error will be cleared. Another, more economical way, is to manually remove drum unit, remove square end caps located on both ends, and vacuum out or carefully dump into a trash bag. Just be careful...dumping toner is messy.
2answers
Xerox workcentre m24 replace toner even if the toner is new
There is no need to worry a lot what you can do is that, just open the toner access door located at the front of the printer and then you can scroll down the list of cartridges until you find the one which is giving you the message of Replacing toner.
Then press the button "1" to reset the display toner settings. If still you find any of the difficulties then we have a best place available which can actually sort out your issue and they are Micro Toner Supplies and their official website is where you can find a lot of things is https://www.microtonersupplies.com.au/toner/xerox-toner-cartridges
Basically these guys(Xerox Toner Cartridges) are famous for supplying cartridges at a specific cost and to your mentioned area but in this site there is a contact option available where you can contact them and can solve you issue. Hope this may work to you and if still you find any difficult even after accessing the prescribed website then there are many other websites where you can find better solutions.
9helpful
2answers
Brother dcp 7055 printer toner ended error
i haver Brother Laserjet DCP 7055 printer. Once i refilled its toner but now on 2nd time i refilled it the printer is gives an "Toner Ended" error & replace the toner message.... Pls help meto solve it... Thanks lucky bareilly
2helpful
Printer model HP Laserjet CP2025, at display panel appear 'supply memory error'. How to solve it. Thank you
This is a problem with the toner cartridge, check the code at the end of the error message and that will tell you which toner is defective.
Al
My HL-2140 brother laser printer is flashing a red error
1>If the toner lite is blinking , it's mean the toner life near to end. In these case please replace the toner cartridge.
2>f the drum lite is blinking , it's mean the drum life near to end. In these case please replace the drum.
I hope it will help to solve your printer problem.
Norman Weimar
Norman Weimar
k24674
