Barnes & Noble stopped doing APPS. they still do book.
Other books can also be put on you NOOK. ProjectGutenberg now has over 30,000 free titles. You basically download onto your computer and read it using Calibre, a free e-reader. Or, then plug the Nook into your computer and transfer the e-book to your Nook. The non-B&N books can't be in the same place as B&N books, but you can make separate folders under My Files. For other books, if they are epub or PDF, you can read them on Nook. (Comic books are often in .cba, .cb7 which can also be read.) Some sites (Google Play and LULU for example) have multiple formats and it is not easy to learn which will work on your Nook.
Have you checked the restriction settings on your Nook? Try checking to make sure the restriction settings have not been accidently turned on for the browser.
Press the ? button to display the quick nav.
Tap Settings.
Tap the Security option.
Tap Restrictions.
Tap the Restrictions check box.
Enter your four-digit code for Restrictions.
Tap the Browser check box so that it's not checked.
Go to settings, then device information. While pressing the volume up button, tap above the volume bar and a popup menu will appear. Uncheck "Enable demo mode", then power down your Nook. When you restart it, the Nook should be in regular mode.
