Proscan 10.1-Inch Internet Tablet, Capacitive Touch Screen, Android 4.0 with Front Camera, 1.2 GHz, 1 GB RAM" Logo
Shirley Piercey Posted on Feb 14, 2015
How do I fix my proscan tablet the system ui has stopped
I have tried to reset but nothing happens
JoseGala
Level 1:
Problem Solver:
  • Contributor 16 Answers
  • Posted on Feb 16, 2015
JoseGala
Contributor
Level 1:
Problem Solver:
Answers
16
Questions
Helped
6175
Points
34
You need to reset using a pin inserted in the hole in the back. Pressing multiple times as deep as 1 inch
1 Related Answer
jermsgood
Jermaine Gooden
  • 59 Answers
  • Posted on Sep 07, 2014
SOURCE: How do I get my Proscan tablet activated with a keyboard that came with a case?
This should be able to help you...
My dell tablet has : Unfortunately, System UI has stopped. Haw can I fix this?
if your have faced this issue while using your computer. Then you need to follow these steps to fix UI Failed to Load on windows
https://www.mygeekshelp.com/avast-ui-failed-to-load-after-windows-10-update
What happens when you hit the internal reset button?
How do I get the message unfortunately com.android.phone off my sons proscan tablet?
Have you tried the reset with the paper clip in the reset hole yet.?
I think the reset hole is on the back. Press gently into the hole with a paper clip.
You will lose all data however and it will go back to factory default settings.
This is a common problem with Proscan tablets. Make sure you charge the battery fully before starting.
3answers
2answers
How to fix my proscan will not run google it keeps crasing
Go into settings.
Apps. Select Google.
Clear cache.
If that doesn't work select uninstall updates. You will be questioned if you want to reinstall factory version. Select yes.
If that doesn't work back up and reset tablet.
I am trying to factory reset my irulu AK 303 tablet after it got locked on the too many pattern attempts page by holding down power and volume down but nothing seems to happen What else could I try
I am not familiar with your brand of tablet, but my Proscan 10" one has a reset button on the back. If you can find it listed in the owners manual or somewhere on the tablet, I would try that next.
Received in the mail today 3 of the 7" Genesis Prime tablets for my kids. One of the tablets is saying "Unfortunately the UI stopped & Unfortunately the Wizard has stopped" I didn't have any problems...
UI means "user interface." It likely means "GUI"--"graphical user interface"--pretty pictures on a screen upon which one points and clicks. Thus, you can't use the touchscreen. Try a "soft" reset. If that's ineffective, try a hard reset--often called something like "Restore Factory Settings." If you find the manual, physically--or online via a mfr. site PDF, follow it's procedure for those. Otherwise, try pressing the power on button for 20 seconds or so--see if the screen then offers hard reset. Press "Yes" or otherwise assent.
Top Proscan Tablets & eReaders Experts
 Mikey
Mikey
Ngoro
ADMIN Andrew
ADMIN Andrew
Are you a Proscan Tablet and eReader Expert? Answer questions, earn points and help others
