Craftsman Snow Blower / Snowblower Bottom Cover : Logo
A
Anonymous Posted on Feb 13, 2015
Snowblower....auger takes time to get going...like five minutes...it will struggle to start spinning then eventually warms up and is fine....whats the issue?
  • Anonymous Feb 13, 2015
    also....there is no snow/ice in the way to slow anything down
Paul S
Level 1:
New Friend:
Problem Solver:
  • Contributor 14 Answers
  • Posted on Feb 14, 2015
Paul S
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
14
Questions
0
Helped
5707
Points
57
It is most likely your auger drive belts. There are two of them, and they need to be replaced periodically. Your manual should describe in detail as to how to replace the belts. Always start by removing the spark plug wire.
Improper gearcase lubricant could also cause problems. Your manual should tell you specifically what to use in the gearcase, and how to fill it. Also look for grease fittings on the auger and use a low-temp grease to service those fittings.
Lastly; behind the auger is the impeller shaft. Reach in and see if it wiggles. If it does, then have your impeller bearing replaced.
Ariens snowblower 932102 auger will not stop spinning
It seems to be a common issue when you change a belt! Most people have it the other was when they won't turn.
https://www.google.com/search?q=Ariens+snowblower+932102+auger+will+not+stop+spinning
2answers
Auger on snowblower doesn't engage
how do I find good anime movie on Netflix help me fam
Feb 11, 2015 • Mtd Garden
2answers
MTD 8/26 snowblower
Either there is a belt or a chain off, or the linkage became disconnected or there is a pin sheared. Take one of the three. If you have power spinning like you said then those are your choices! Best of luck to you. Hope you beat the weather!
1helpful
2answers
Pull starter won't pull
ALL-- Power Equipment-- needs to be inside & warm,
NOT in an outside shed
Have to warm it up inside-neighbors garage!
2answers
Augur wont turn on troy bilt model 2410 snowblower,stall s out when i engage the augur
ICE OR HARD PACKED SNOW IN BLOWER HOUSING
warm up or pour hot water down chute to thaw out
1helpful
2answers
Rear auger turns front auger not turning
From your information above, it sounds like a broken gear or tooth on the auger gearbox. (this could happen if you hit an object and your shear pin did not break, instead breaking your gear) Hope this helps.
I have an Ariens 1128 Snowblower. Here's the problem, everything seems to function fine, impeller spins, augers spin, howerver, when I put it into any real snow (more than 6-12 inches) the impeller and...
Hi, I will try to help you with this problem. I think the problem might be an adjustment issue. If you take the cover, usually plastic, situated just in front of the engine housing, you will see the belts and pulleys. Without the engine running, press on the auger/impeller lever, and if you look inside you should see how the belt is made to engage the auger pulley. Probably by an idler pulley that pushes on the belt to make it tight to turn the big pulley. That is the most popular way, it is to loosen the bolt on the idler pulley and push it towards the belt so it applies more pressure to the belt to turn the auger pulley and tighten the bolt. There could also be an adjustment on the linkage that might be adjustable. Another possibility is that the belt is worn and is riding on the bottom of the pulleys therefore not providing enough friction to turn the pulleys properly. I think if you take a good look at that system you will comprehend it. Hope this is helpful. All the best and good luck. I will gladly answer any other questions.
Feb 02, 2011 • Garden
1helpful
I have an Ariens 926LE snowblower. The blower spins but the auger spins slowly. It barely throws snow. Some times the auger stops spinning. Shear pins are fine.
Hi, The blower spins at full speed? If it does the belt, pulley, and shaft are good. Look at the shaft from the fan to the gear box while it's running and that shaft should be turning at the speed of the fan.
If the blower spins at full speed and the auger doesn't the most likely problem is the worm gear transmission from the blower shaft to the auger shaft.
A good way to visually inspect this is: With the machine turned off and the spark plug wire unhooked go to the front and try to rotate the auger by hand. If the gear box is good you will only be able to move the auger less than an inch. If the box is bad you will be able to move the auger a lot farther. While you are there recheck your shear pins.
You can also remove the blower drive belt and have someone turn the pulley by hand while you watch the auger. Put resistance on the auger with your gloved hand. If the box is good the auger will move smoothly in you hand. If it is bad, it will ****, move roughly, or stop.
While the other person is turning the pulley and you have some resistance on the auger look closely at the shaft running from the gearbox back to the blower. On some models there is a connecting sleeve and the roll pin that connects the sleeve to the shaft and gearbox will break.
If the gearbox is bad, it will have to be replaced as a complete unit.
Was this helpful? If you have any other questions, please ask.
Jan 10, 2011 • Garden
3helpful
John Deere Snowblower - wheel won't spin
yes 2 solutions. the sheer pins have got broken down on that auger that wont spin, they go through the middle bar. easy fix. about 2 dollar.
The other thing is. The drive belt located directly in the middle of the machine has a plastic cover over it has slipped off or is broken.
THis is a little more tricky as you split the machine taking off the collection cage usually to fix. I charge 89 dollars in my shop to do these.
Its not hard if you pay attention to where you need to take off the parts.
Top Craftsman Garden Experts
john h
Jay Finke
Jay Finke
Sean Wright
Sean Wright
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
