Hi, my name is John. Try turning your MIC-GAIN to MAX. Also have someone check the SWR on the antenna, Radio shack will do it for free or a CB Shack....hope this was helpful...
If your radio is a Galaxy DX66V then I believe that the Turner Road King should be wired to the 4 pin plug with:
Pin > Usage > Connection
1 > Ground > Shield & Red
2 > Mic Audio > White
3 > Transmit > Blue
4 > Receive > Black
If you want to confirm the mic wire colors use an ohm meter to test the following:
With the mic button not pressed:
Shield and Yellow are connected together
Red and Black are connected together
Blue is not connected to anything
White is not connected to anything
With the mic button pressed:
Shield and White are connected through the microphone transformer
Red and Blue are connected together
Yellow is not connected to anything
Black is not connected to anything
the problem is one you may not be able to work on . It will take a scope and a spectrum analyzer along with an RFSG to get this one working . Some simple ??. Does the radio come on ? Check with your hand passing over the radio to check for hot spots? The best thing to do is get it to a tech and let them work on it.
what year we talkin hear ?sounds like throttle position Valve needs to be looked at for hook up or lack of Pedal ,look to see if the Pedal is Hooked Up see if it is wiring or cable replace it
so,what numbers does it show? If you are at 27.187 or 27.183 it should be no problem that little amount of frequency differance won't make any differance. Now if you were at 27.180 or 190 then you would be going into another band width.
