Tablets & eReaders Logo
A
Anonymous Posted on Feb 13, 2015
How to get out of safe mode
Shutdown and restarted
drvalentine
Level 3:
Master:
  • Master 876 Answers
  • Posted on Feb 13, 2015
drvalentine
Master
Level 3:
Master:
Answers
876
Questions
0
Helped
255233
Points
4299
Safe mode unlock
Turn on and use safe mode
Safe mode allows you to turn on the device with third-party apps disabled. Then you can easily uninstall apps that may be causing a conflict or software problem.
Turn the device off.
Press and hold the Power key.
When Samsung appears on the screen, release the Power key.
Immediately after releasing the Power key, press and hold the Volume down key.
Continue to hold the Volume down key until the device finishes restarting.
Release the Volume down key when you see Safe Mode on the device.
Uninstall apps that are causing a problem.
Turn off safe mode
Tap Restart.
The devices restarts in normal mode.
1helpful
Hw to get safe mode off a Nextbook tablet
To get out of Safe Mode, please try the following.
1. Touch and Hold the "Power" key.
2. Tap "Power Off".
3. Once the tablet is off, Touch and Hold the "Power" key again to restart.
The tablet should now be out of "Safe Mode".
If the "Safe Mode" is still running after you restart your phone, I would then check to make sure your "Volume Down" button is not stuck. Check to see if it has anything stuck in it as well, dust, etc. Anything like this can cause the phone to go into, and get stuck in, "Safe Mode".
If that doesn't work try this...
Use the "Status Bar" to turn off "Safe Mode'. Pull down (swipe) the "Status Bar" of your phone. Now tap the "Safe Mode" button. This should turn "Safe Mode" off. Now your phone will automatically restart, so that it boots up out of "Safe Mode".
And lastly...
If you want to get rid of/disable "Safe Mode".
1. First turn off the tablet.
2. Next press and hold "Power" until you see the manufacturers logo on the screen, then release the power button.
3. "Quickly" press "Volume Down" and hold it for few seconds until you see the message "Safe Mode: OFF" or something similar.
4. If you wanted re-enable it, simply repeat the steps above, and you should see "Safe mode: ON" rather than off.
I’m happy to assist further over the phone at https://www.6ya.com/expert/latoya_8ed1bf3dc615c15d
Removal of safe mode for x1010 mecer tablet
To help you understand to get your x1010 tablet out of safe mode, please follow the step-by-step instructions given below:
- Restart your device by holding the power button, then tap Power off.
- Tap Ok to confirm.
- Power the device on. Your tablet should now be out of safe mode.
If the device is still in safe mode use one of the following methods. Uninstall the last application you installed:
- From the Apps menu, tap on Settings.
- Tap on the app and then tap on Uninstall.
- Restart your device.
GuruAid.com
Why does my nextbook keep asking me if I want to put it in safe mode?
The device went into safe mode because the app that you downloaded was not a safe application. The device does this so that the application cannot cause more problems to your device. Even though the app was downloaded from the app store it was not deemed safe by your device. Here are some tips that will help you to get your device out of safe mode: -Ensure that if you have a case on your device that you take it off being that the case may be holding the volume button causing you to boot into safe mode -Try turning the device off then back on to get out of safe mode -Power off your device, then reboot by holding the power button + volume up key, then in the boot menu select reboot device -This is sometimes caused by the users accidentally tapping safe mode when cutting the device on so simply restart your device Most users have success by simply restarting the device in order to be able to get out of safe mode. Do your best to restart or reboot your device before you have to perform a hard reset to get the app off of your device to no longer go into safe mode In order to hard reset -Power off device -Hold down volume up + power -Release at the boot menu -Use the volume keys to highlight factory reset -Press the power button to select factory reset -After this the device will begin to reset itself -After it resets itself use the volume keys to highlight reboot device -press the power button to have your device rebooted in its factory settings
How do I get out of Safe Mode?
In this case Kindle technician might be help you Just give them a call Kindle Technical Support Registration 877 690 9305
1helpful
How do I get my nextbook tablet out of safe mode?
How do I get my kindle fire hd out of safe mode
Please press and hold down the power button for 25-30 seconds until the Kindle restarts or asks for Shutdown. If it asks for Shutdown then please shut down the device and power it back on
How do we get our Kindle Fire HD out of safe mode?
try press and hold down the power button for 25-30 seconds until the Kindle restarts or asks for Shutdown. If it asks for Shutdown then please shut down the device and power it back on. If that does not work try
with the Kindle ON press and Hold the power button And volume down button, until it shuts off, then turn it back on.
Top Tablets & eReaders Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
