WHAT CAN I DO TO FIX THE PROBLEM
SOURCE: how do i watch movies on a philips 42pfl5603d/f7 from flash drive
the flash drive connection is usually for viewing pictures, but in most cases its used to upgrade the tv
SOURCE: where do and how do i upgrade my philips tv
Usually a service tech employed by Phillips does the upgrades but you might check the phillips website and look for any upgrades for your tv, you might just be able to download a file which you can then put on a flash drive and upgrade
SOURCE: Looking for replacement panel for Philips 42'' model #42pfl5603d
Visit Anrews Elctronics.com. Ask for a salvage part.
SOURCE: model #42PFL5603D/27, approx. 2 yrs old. Fine one
You have to check the 24vdc power supply to see if it is putting out the voltage or the backlight inverter board has failed. Disconnect the inverter board and see if the 24vdc come back.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
SOURCE: lines going through the display
I had a similar problem with my 42 in Philips LCD HDTV.
Here was the problem. My Power Supply Board had several bad capacitors. I opened my TV (warranty was expired ofcourse) and found four bulged capacitors. Many electronics companies were sold capacitors that failed in 2-5 yearsinstead of 10-20. The capacitors failprematurely due to a lack of preservatives. Unfortunately, they were installed in allsorts of devices and cause a wide range of failure problems.
Here are some options for you.
1. Have it fixed by a professional $$$$$$$???????
2. Open your TV and find PSB. Checkfor faulty caps. If you find some (bulgedor leaking) bad caps replace the entire board. The entire board costs around $250 right nowbecause they are in high demand right now. They can be found at tv-part.com but supplies are limited.
3. Remove and then replace individual faulty caps. This takes some soldering skill.
Caps are inexpensive and if you can take care of it yourselfit will save you hundreds.
I have a tip/tutorialon this site that may also help. Itgives step by step instructions for replacing caps on PSB #715t2432-2. If this is your board you are in luck. It's called: Fixing the Philips Turns/shutsoff on its own problem. I'mworking on uploading pictures to help guide people though the process aswell. Let me know if I can do anythingto help.
Hope this helps and Good luck.
Kaufman605
Hi Roulla Kyriakidou, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? what are you trying to watch from where
