One For All URC-4330 Remote Control Logo
A
Anonymous Posted on Feb 12, 2015
I need tv codes for one for all remote 3050b00 to program a venturer tv
Level 3:
Top Expert:
  • One For All Master 76,851 Answers
  • Posted on Feb 13, 2015
One For All Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
15006801
Points
237762
0028,0017,0085. Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Type in the brand name of your device, in the search box [at the top right] of the display window, and press enter to get all related posts. It will make surf easy.
I have a oneforall remote urc 3050B00 I have a LG smart TV that I need the code for the remote
Here are the steps to program your OneForAll URC 3050B00 remote to control your LG smart TV:
Turn on your LG smart TV.
Press and hold the "TV" button on your OneForAll remote until the LED light on the remote turns on and stays on.
Enter the 4-digit code for LG TVs. The most common codes for LG TVs are 0030, 0056, 0178, 1265, and 1398, but you can also find a complete list of codes on the OneForAll website or in the manual that came with your remote.
Press the "Power" button on the OneForAll remote. If the TV turns off, the code has been successfully entered. If the TV does not turn off, repeat steps 2-4 with a different code until you find the correct one.
If none of the codes work, you can also try the code search function on your OneForAll remote to automatically find the correct code:
Press and hold the "SET" button on the remote until the LED light blinks twice.
Press the "9" button on the remote. The LED light should blink twice again.
Point the remote at your TV and press the "Power" button repeatedly until the TV turns off.
Press the "OK" button on the OneForAll remote to save the code.
I hope this helps you program your OneForAll remote to control your LG smart TV!
Need tv codeo for one for all remote 3050b00 to program Sylvania tv
0228,0229,0222,0236. Check these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name" in alphabetical order. Pull up older posts. Surf the site with patience. Surf the sites by type in the brand name to your set, in its search box.
http://electro-medical.blogspot.com/
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Need the remote code for a venturer TV
0281,0288,0280. Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls.Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order.Pull up older posts. Surf the site with patience.
Need code remote 3050b00 tv/dvd combo
What manufacturer is the combo tv/dvd? as codes are based on the set rather than the remote. 3050b00 is a universal remote that workes with any set as long as you enter the manufacturers code.
e.g Toshiba = code No 1133 or 1134 You should find a full list here:
http://www.hifi-remote.com/manuals/manual.shtml?URC-3050-codes
Hope this is of help to you.
To program venturer tv to dishnetwork receiver
Hi my nameis Mike Houston of DISH Network and I see you want to program the Venturer TVto our DISH Network receiver. We currently do not have the three digit code(s)for the Venturer TV, what we do have to setup the remote is called a Power Scanand it will find the code to setup the remote to the TV. I will send you the linkto help with the setup; http://www.dishnetwork.com/SupportSection/power-scan-instructions.
I need the code for a zenith sr1641y tv remote. i have a 3050b00 universal
Here you go. This will work with most all universal remote controls. If you don't have the code do the following:
Automatic Programming
With automatic programming, the remote control tests all the codes available on the Code List and assigns the correct code for the selected device. Although this method can be more time-consuming, it eliminates the need to look up codes and enter them manually.
1. Turn off the device with which you want to use the remote control.
2. Press and hold the corresponding button on the remote control
(TV, VCR, SAT, DVD, CAB or AUD) until POWER INDICATOR illuminates. It should take a couple of seconds for the light to remain solid. The remote control is in programming mode.
3. Press and release power button. The POWER INDICATOR flashes once and stays on indicating the unit is in Power Scan mode.
4. Press CHANNEL up or CHANNEL down repeatedly until the device turns on.
5. When the device turns on, press OK to store the code.
Note:
• To exit without storing the code, press BACK.
• T he unit will search for the next code or the previous code if you press
CHANNEL up or CHANNEL down after the device turns on. (go slow you need to press OK when the TV turns on) if you mess up turn TV off and start over.
6. Press any other button. If the device responds, the remote control has been programmed. If the device does not respond, repeat steps 2-5.
Fill free to ask me questions about anything..........................
2answers
Need codes to program remote
most universal remotes have a auto program mode or coad if you can't find a coad to match your brand
Top One For All Televison & Video Experts
ExpressFiX
ExpressFiX
ZJ Limited
ZJ Limited
Are you an One For All Televison and Video Expert? Answer questions, earn points and help others
