I have purchased songs but they only appear under another app. I want to move them into specific playlists
You may try to copy it to your device card, then from your application drawer, tap your default music application, then while you are on default music application, select the folders where you copy your purchased music, then, from there you can create a playlist.
by the way, playlist is only a list of your music shortcuts, where it is located, what is the extension file and what is the title..
this may also apply on the other music application be it downloaded or default.
good luck..
SOURCE: My galaxy tab was playing music and the song
the song is most likely corrupt. delete the file and reupload it
SOURCE: moving apps onto sd card
Hi in order to move apps to sd card you need place the sd card in your tablet go to settings then applications. On the next screen you've got the list of downloaded apps just clik on one of them and then properties screen come up on which in the second row you will see button move to sd card. Just press on it wait few seconds and your apps is moved. Repeat this for every app but bear in mind that some of the apps can't be moved to sd card Regards
Note: These steps clear data from the device. SD card data like your photos and music are not erased unless you choose to format the SD card.
2. Release the Power button when you see the Samsung logo, but continue to hold Volume Upuntil the recovery screen appears.
3. Use the Volume buttons to navigate the menu and select wipe data / factory reset. PressHome to choose the selection.
4. Press Volume Up continue.
The Galaxy Tab should then go through the hard reset process.
If you have access to the OS, you can also perform a hard reset in Settings.
1. Open the Settings app.
2. Select Privacy.
3. Choose Factory data reset.
