Question about KitchenAid Microwave Ovens
How to change the torsion springs in my kitchenaid microwave oven KEMC308KSS01
    Master:
  • 505 Answers
Replacing the spring isn't very difficult if you're mechanically inclined.
You're basically removing a few screws, the front panel of the door is removed exposing only the glass part that's still hinged. The springs are exposed. Hopefully one spring is still in tack so you can see the orientation of how to put the replacement in. It's not very intuitive on how to do this part.
Check this link for more details:
Microwave Repair
Posted on Feb 12, 2015
6ya staff
SOURCE:
Door spring on build in microwave oven
Is this a combination built-in oven with microwave on top? And is this microwave one in which the door opens downward like a regular oven? If so, then this is a common problem for this oven/microwave combo, but replacing the spring is not a job for amatures. It takes a professional 45 minutes typically to do this job. It involves removing trim pieces, removing screws that hold the microwave oven in place, pulling the microwave out a couple of inches, and taking the door apart to get to the 2 torsion-bar springs. Replacing them is quite tricky, as is re-assembling the door. I recommend calling Sears Service (1-800-469-4663) to get a seasoned repairman to come out and fix your oven/microwave. Cost will probably be between $180 to $200.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Jan 25, 2015 | KitchenAid Microwave Ovens
Door spring on microwave
KA MW use torsion springs 2 about 50 a piece
How to replace torsion spring in the microwave door
If this is the flip down door. You will need to take apart the side cover of the unit to fasten the spring. Once you have done that you need to put a pen or something to hook it so it doesn't drop down in the unit. If you are unable to hook the spring in the door. You must take the outer cover off the door to hook the spring and then replace the cover. You may find this to be a two person job and may be easier to hook the door before you hook the unit. Some doors are different then others.
Feb 08, 2011 | KitchenAid Microwave Convection Oven
Hi there, unit worked fine this morning heating coffee, now has a different tone, and not heating. Timer works, interior light comes on, turn table rotating. Unit is a KEMC308KSS01
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
Dec 21, 2010 | KitchenAid Microwave Convection Oven
Microwave Oven Door Spring Replacement
Remove the front panel by removing the screws located on the inside of the door (note hold door inplace, since it is heavy and will fall out after screws removed). Unscrew screws located on bottom of plastic retainer (2 each) Remove tension spring. Note 2 are included right and left. Note color of spring on end, different springs for different door types, stainless, black,beige or white. Replace all in reverse order.
Mar 26, 2009 | KitchenAid Microwave Ovens
Broken torsion spring needs to be replaced
There are indeed two springs that "cross" each other, and they must be both be replaced to ensure full strength.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Dec 24, 2008 | KitchenAid KHMS147HS Microwave Oven
Microwave Ovens Logo
175 people viewed this question
Top KitchenAid Microwave Ovens Experts
William Miller
William Miller
Thomas F. Schneider
Jerry Greenberg
Jerry Greenberg
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
